HI
For shure this subject has been mentioned elsewhere, but I cant find a answer to my problems:
-How to paire the Beoremote one to the BS Moment?
-How to M5, pairing on the One does not change from pairing to connect.
Thank you for yor hints!
Ruedi
BeoVision11, BeoVision10, BeoSound 5, BeoSound 3500, BeoLab 9, BeoLab 4, BeoLab 6000, BeoLab 8000, BeoSound 3200, Beosound Moment,NL/ML converter, delaybox, var.BeoPlay Speakers
Thank you Jeff
When I switch the BRone to Beo4 I can trigger Beosound 3500 and other IR products, but BSmoment does not react.
Can you tell if my BRone is IR onyly or IR/ BT:
Serial Nr. 2642275
FW: 1.1.1549
BL: 1.0974
Apr. 29.2015
Serial number missing 1 number. its should be 8 and not 7 number.
But seems its a non BT because of the date 2015. Beoremote one BT was introduce in 2016.
Sorry,
S# is 26420275
I believe you must set the BeoRemote One to "BeoSound" mode. However, the IR on the Moment is shut off if you're using it in an integrated setup with a BeoVision. Both of my Moments are in such integrated setups using the speakers of the BeoVisions. Therefore, I don't use the remote directly with the Moment.
Thank you, my setup is with a NL/ML converter. by switching on the BS moment on the panel it activates the BS3200. Then I can get the signal on any ML product. The BSmoment is not related to the BV11.
How can I find out if the IR reception is ON or OFF on the BS moment?
