I have had this unit packed away until I have moved.
Now unpacked I cannot find where the socket attached to the mains plug fits into the unit?
Can anyone help me please?
Hi and welcome!
Google 'beosound century connection panel' and select images. You will see the mains connection at the first hit
Viewed from the back, it's right at the bottom edge towards the right hand side
Here:
Thank you I will have a look to see if I can attach the wire.
I will get back to you if any problems.
My cable has 2 holes on the end that push into the unit is that correct?
Jean
JENHARA5: My cable has 2 holes on the end that push into the unit is that correct?
Yes that's correct - it's a standard figure-of-eight (C7) power cable; they are widely used across all manner of electric devices.
