Beomaster 4000 went bang!
bambam
Posts 5
bambam Posted: Mon, Dec 17 2012 6:40 PM
Hi
My Beomaster 4000 went bang a while back - I think someone had tried to switch it off but not done it properly and when I actually did it, it made a loud noise and hasn't worked since!  This was a while back so the details are sketchy, but now that I've cleared some space again I want to put it back into commission.
At the time I found that one of the anti-surge fuses had blown so I replaced but no joy.
Anything simple I should try?
Cheers
PS While we're at it, any way to reduce the transformer 'hum' whilst on standby??
Step1
Manchester, UK
Posts 1,268
Step1 replied on Mon, Dec 17 2012 8:49 PM
bambam:
SOrry I completely miss-read this as Beogram lol anyway it does sound like you have lost an output stage or similar... How are you with reading circuit diagrams and component level servicing?
Olly
bambam
Posts 5
bambam replied on Tue, Dec 18 2012 9:24 AM
Errrr - not competent at all!  I was hoping that I could replace a blown fuse or similar inside!
If I start messing about with circuits and the like I'll just cause more problems!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Dec 18 2012 11:40 AM
Beomaster 4000 does not have a standby function.
Did the bang come from the speakers (blown output stage, power supply etc.) or
from the physical Beomaster (blown capacitor, power switch etc.) ?
bambam
Posts 5
bambam replied on Tue, Dec 18 2012 1:08 PM
From the physical Beomaster.  Definitely not the speakers.
bambam
Posts 5
bambam replied on Tue, Dec 18 2012 3:21 PM
Dillen:
You're right.  I meant when the unit is ON but nothing is playing.
Cheers
Dillen
Posts 13,191
Dillen replied on Tue, Dec 18 2012 4:35 PM
The humming is from the transformer itself. Only cure so far is to find a replacement with no hum from a donor.
And, to be honest, the other issue does not sound like something I would recommend to someone with next to
no electronic skills or experience. In fact, the transformer replacement could also fall into this category.
bambam
Posts 5
bambam replied on Tue, Dec 18 2012 4:45 PM
That's what I thought!  I'll get it repaired by a professional as I have now cleared some space to put it and the Beogram 4000 into action again.
Thanks for the advice and I'm glad I stayed away from opening it up!
Page 1 of 1 (8 items) | RSS
