Beosystem 2500 / Beosound Overture Light Bulb
This post has 36 Replies | 0 Followers
dsid2000
Posts 16
dsid2000 Posted: Thu, Dec 20 2012 1:47 AM
Hello all,
I own a B&O Beosystem 2500 (aka Beosound Overture) and one of the 4 ambient lights surrounding the CD and tape player is burned out.  I verified this by taking it apart and indeed the filment is detached.  Does anyone know what kind of light bulb I need and/or who may sell them for the system?  I assume I can learn how to unsolder the light bulb and reattach a new one.
Any assistance would greatly be appreciated.  My system is 20+ years old and I'm graceful that something so minor has happened but it really deters from the attractiveness of the system.
Thank you very much!
David
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Good  Luck finding out, I never did. In the end I bought the spare part from B&O. They are sold mounted on the little pcb and are a HORRENDOUS !!price
Regards Graham
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Thu, Dec 20 2012 10:12 PM
Well, last year after Xmas has ended I bought several Xmas decoration lights quite cheap and maybe I can use these lightbulbs instead of those overpriced prices B&O is asking! Let's see how that works out!
Brengen & Ophalen
Max
Warsaw, Poland
Posts 25
Max replied on Fri, Dec 21 2012 7:13 PM
Does anyone can help me with replacement of the bulb? What i have to do step by step - any advice,or support? It seems to be covered by electronic board...or how to call this ;-)
Thanks in advance!
Max
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Dec 21 2012 8:10 PM
It's just a little PCB with 2 tracks on it to keep the lightbulb in place. Nothing special, however I would advise you to keep the tiny PCB and replace it with an alternative lightbulb.
Brengen & Ophalen
Max
Warsaw, Poland
Posts 25
Max replied on Fri, Dec 21 2012 8:50 PM
OK, thank you for advise. But how to get to the bulb inside Ouverture? It seems to be covered by some components. Especially the bulbs dedicated to light up the tape are hardly accessible in my opinion...
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Dec 21 2012 8:57 PM
I will post a pictured guideline on your thread how to do that as soon as I found the alternative lightbulbs. Probably this weekend! Cheers...
Brengen & Ophalen
Max
Warsaw, Poland
Posts 25
Max replied on Fri, Dec 21 2012 9:20 PM
Great! I'm looking forward!
dsid2000
Posts 16
dsid2000 replied on Fri, Dec 21 2012 9:42 PM
Hi Leslie and Max,
Thank goodness I'm not the only one struggling with this problem.  I called a B&O repair center and they didn't have the part nor could they provide a part number.  To verify that the bulb is out, I followed this youtube video minus the laser removal.
http://www.youtube.com/watch?v=bcrPJcZOwfg
Leslie, I would very much be appreciative if you can determine an alternative bulb to use and how to properly remove and reattach a new bulb.  B&O certainly doesn't make it easily repairable.
Thanks and happy holidays!
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Dec 21 2012 10:04 PM
I saw and forgot that video! Pretty good, I like those kind of instructions, saves you lots of bla bla..
The first part shows you how to remove the frontplate in order to get easy acces to the lightbulbs.
I hope I can find a cheap alternative for the bulbs and will post my findings!
Happy Xmas holidays to you as well...
Brengen & Ophalen
joeyboygolf
Posts 4,188
dsid2000:
Hi Leslie and Max,
The part number is available in all the service manuals!!
Regards Graham
dsid2000
Posts 16
dsid2000 replied on Fri, Dec 21 2012 10:58 PM
I found it!!!
I called a B&O repair shop near Atlanta GA and the great guys there hooked me up!  For a light bulb it's a bit pricy but there aren't many choices $12.33 + $2 shipping.  This is the light bulb + circuit board so I must unsolder and resolder 2 wires but it seems quite easy.
Part #: 8230100
Modular Electronics
http://aminaaudio.com/service.html
1-770-410-1122
Contact: Benny Amina
I should receive the light bulb in a few days and I will try to repair my system.  I'm so excited!
Søren Mexico
Mexico City
Posts 6,411
P{ease report back with the result, do you change only one or all 4
Max
Warsaw, Poland
Posts 25
Max replied on Sun, Dec 30 2012 10:05 PM
So any news regarding bulb replacement?
MediaBobNY
Greenwich Village, NYC
Posts 1,106
joeyboygolf:
I just got off the phone with Benny Amina @ Modular Electronics.   He said a 12V / 70mA bulb would do the trick, which I found here.   'Gonna give it a try on my Beosound and will report back.  Benny also said that all the bulbs should be replaced so that the brightness matches.
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, Jan 10 2014 9:39 PM
That looks like a LED lamp. I think you need a filament lamp.
//Bo.
A long list...
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Jan 10 2014 9:39 PM
That's correct and quite easy to replace.
Brengen & Ophalen
MediaBobNY
Posts 1,106
MediaBobNY replied on Fri, Jan 10 2014 10:08 PM
BO:
?  I see no indication that it's LED.
Leslie, are you saying this bulb is ok?
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Jan 10 2014 10:21 PM
It's not a led, just an ordinary light bulb. Shall I send you two for free?
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Jan 10 2014 10:22 PM
It's not a led, just an ordinary light bulb. Shall I send you two for free Bob?
Brengen & Ophalen
MediaBobNY
Posts 1,106
MediaBobNY replied on Fri, Jan 10 2014 10:24 PM
LOL - thanks for offering Leslie, but no  Smile
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Jan 10 2014 10:33 PM
The bulb can be replaced and you can still use the excisting small pcb by desoldering the defect light bulb. Some things looks complicated but it isn't. Don't buy them at the dealer, cost you for such a simple part a fortune.
Brengen & Ophalen
MediaBobNY
Posts 1,106
MediaBobNY replied on Fri, Jan 10 2014 10:36 PM
That's what Benny Amina said.  But from the looks of the previous posts on this thread, people have been buying the pcb+bulb.
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Jan 10 2014 10:38 PM
You can't buy them seperately, it's one partnumber.
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Jan 10 2014 10:40 PM
Did you managed how to replace them on your 3200?
Brengen & Ophalen
MediaBobNY
Posts 1,106
MediaBobNY replied on Fri, Jan 10 2014 10:45 PM
Leslie:
I know - that's what I meant. Gonna do my 3200 as soon as I receive the bulbs and buy a soldering iron/solder.  Which end is the hot one?  Embarrassed
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Jan 10 2014 10:51 PM
Try the metal end and you will find out. By some plasters as well...
Brengen & Ophalen
MediaBobNY
Posts 1,106
MediaBobNY replied on Fri, Jan 10 2014 10:59 PM
I just watched half a dozen soldering tutorials on youtube and not one of them mentioned 'plasters'.   What are they?   Would installatioin be easier if I bought the pcb part?
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Jan 10 2014 11:11 PM
Sorry Bob, tried to be funny. Plasters, something you put on when you burn your fingers, band aid?
You still need to solder even with the complete pcb.
Brengen & Ophalen
MediaBobNY
Posts 1,106
MediaBobNY replied on Fri, Jan 10 2014 11:17 PM
Ahh - lost in translation.   Band-Aids.   Laughing
james
scotland
Posts 13
james replied on Sat, May 17 2014 11:33 PM
don't know if this is of use as information, got them in a bag of spares i bought from ebay
might be the right part to replace just the bulbs, might not.
Leslie
Posts 5,423
Silver Member
Leslie replied on Mon, May 19 2014 10:25 PM
I think it should be a 5V lightbulb. If you need I can give you one.
Brengen & Ophalen
james
scotland
Posts 13
james replied on Sat, Jun 14 2014 7:07 PM
thanks for the offer leslie, but i have a few spares of the type on the right of the picture already.
antoinepsimons
Posts 2
He Guys!
I've been looking everywhere online to find some info about light bulb replacement for an 'old' BS 2500 from '91 of a friend of mine. There was a suggestion to use a 12 V 70 mA bulb. Well, I today used four 12 V 80 mA bulbs, but the light is too soft. Although I replaced all the four of them to have matching colours, they are just not bright enough.
Replacement -by the way, for those who are into soldering- really is a peace of cake once you manage to open up the two black plastic front covers.
Guide: Unplug power in window open position. Remove the windows, remove the left and right plastic black front covers on the side (you actually do not need to remove the back cover, I found out), remove the 8 screws on the left and right of the front grey element that holds the cd-clamp and buttons, and there you go: full access to those four tiny prints with the bulb on the back. Bend the metal carefully to release the prints, and there you go...
Even though the light of the 12 V bulbs is not that bright as the original bulb (I think the original will be a 5 V bulb, I guess, which will shine brighter), my friend who's BS2500 light broke down is satisfied with the less bright result. Therefore I won't try another 'brighter' bulb. If in a few years my own BS3000's lights will break down, I'll give it a new try :p
I wanted to upload some pictures.... but how?
Regards, Antoine.
matador43
Posts 1,373
Hi Alls,
Today, I replaced one of the two bulbs in my recent Beosound 2300.
I used a 5v 60mA bulb (1,75€ in Paris) and didn't even needed to change the other one: same brightness and same color open or closed, even though the bulb is slightly smaller.
Cheers.
ed7
Posts 106
ed7 replied on Mon, Sep 9 2019 5:37 PM
There is one one eBay now  $15.97 p+p
bigbruggsy
Posts 131
Silver Member
bigbruggsy replied on Tue, Sep 28 2021 10:38 PM
I just replaced my globes with these. https://au.rs-online.com/web/p/incandescent-light-bulbs/0106256
Nice and easy soldering job, just solder off the old globes from the little PCB, then solder these new ones in.
Beolab 8000 x 2
Beolab 1
Beolab 2
Beovision 7-40
Beosound 9000
Beosound Ouverture
Beolit 12
Page 1 of 1 (37 items) | RSS
