Raeuber: Razlaw: Not always true. I have done some playing around with option settings in an effort to get the timer on the BV7 to turn on the BV10 to DTV where the two are linked only by MasterLink. If I set both the 7 and the 10 to option 2, the timer in the 7 will turn the 10 on AND the motorized stand on the 10 turns it to the video position. When the timer turns it off, the motorized stand returns to standby position. You are correct that the 7 does not turn when activated by a timer. Very interesting, I cannot check this, because my BV 10 is wall-mounted. Razlaw: Of course as there is no video connection between the two, just Masterlink, there is no image on the 10 as a result of the timer. However, this problem is solved as the 10 has its own satellite box with a timer so the satellite box is merely programmed to turn on and select a channel at same time as BV7 sends turn on command to the BV10. In that way it is possible to have the BV7 turn both TVs on and off at set times with both TVS displaying the chosen channel. Very clever. But setting both TVs to option 2 is no "official" solution from B&O, because this way you have two video masters in your setup.
Hello Razlaw,
can you please tell me what happens if you set BV 7 to option 2 and BV 10 to option 6 (your standard settings) and then set a timer for DTV to be executed on BV 7 AND BV 10?
For sure BV 7 will turn on and you will get picture and sound. But what happens on your BV 10? Will it turn on and if so, will you hear the sound of satellite box connected to BV 7 or BV 10?
Thanks!
Regards
Räuber
I wonder if there are differences between North American and European software versions?
I just tried BV7 in option 2, BV10 in options 1. Timer in BV7 turns both on. My recollection from doing this in the past is same result if BV7 is in option 1 and BV10 is in option 2. Also, same result if both are in option 2. However, the the timer in the BV7 will not activate the satellite receiver attached to the BV10. But a timer in the satellite receiver can also be programmed to turn receiver on and to correct channel thus the BV10 will be displaying its own attached source.
With these option settings the audio sources work as normal in the BV7 room but I can not get them to work in the BV10 room. In the past I was able to do so using one of the link functions. Not sure what I did then.
