HELLO ALL
can someone help me configure my remote to start using my new 7-55 3D with BR motorised floor stand(high)
BS5 with master 5
LAB5 and LAB 3
APPLE REMOTE NEW
STB from SAGEM ref ICADD 84 HD NC(NUMERICABLE FRANCE)
IF I COULD HAVE THE PREPARED CTX FILE IN FRENCH it would be my XMAS gift
for the moment I am stucked on DTV menu language choice.
THANK YOU SO MUCH TO ALL OF U
Thibault
BV 7-55 3D//BL5//BL3//BS5&BM5//BEO 4&6
To use the .CTX file you would need to import it into the B&O Configuration Tool.
So we must assume you have a copy of the B&O Configuration Tool in which case all the items you state except perhaps the SageM box can be quickly drag-n-drop into your configuration.
The SageM ICADD 84 is not currently in the PUC list, but the ICADD 82 is, so my guess is that there would not be a lot of difference between the two units from an Remote control viewpoint.
I did not understand your statement "I am stucked on DTV menu language choice".
Regards Keith....
