Beo4 how to controle Beogram 5500
This post has 6 Replies | 0 Followers
science49
Posts 9
science49 Posted: Fri, Dec 21 2012 9:31 PM
I have changed Beo 1000 to Beo4 in my Beosystem 5500. It works fine, but how to controle Beogram 5500? Is it a button combination?
Langleyav
Windsor UK
Posts 226
Langleyav replied on Fri, Dec 21 2012 9:46 PM
You need to ADD the comand to the library.
Press list and power buttons simultaniously  and ADD appears in the LCD screen. press GO. then with the Up and Down controls next to the GO button sequence through the hidden commands, When you reach PHONO press the GO button to add it to the LIST command. Press the Power button to return the BEO4 to normal operating condition.When you want to use PHONO just scroll through the LIST until you locate PHONO and then press GO.
Good Luck
Ron
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, Dec 21 2012 10:00 PM
If you have a newer Beo4 you have to add N-Radio which replaced PHONO but still uses the same codes so you will be able to control your BG.
//Bo.
A long list...
science49
Posts 9
science49 replied on Sat, Dec 22 2012 9:48 AM
If I press List with power button it appears "option?" . How to continue?
science49
Posts 9
science49 replied on Sat, Dec 22 2012 9:51 AM
I think it isn`t a newer Beo4 . I don´t find N-Radio.
BO
Halmstad, Sweden
Posts 728
BO replied on Sat, Dec 22 2012 5:47 PM
Press and hold down standby/power press list.
Release both buttons.
Now the display should say ADD?
If not press list repeatedly until it does.
When it says ADD? press GO
Then press list until N-Radio comes up.
Press GO.
Youre done!
//Bo.
A long list...
science49
Posts 9
science49 replied on Sat, Dec 22 2012 6:31 PM
Fine, thank you!
This way I could add "Phono" .
Page 1 of 1 (7 items) | RSS
