Dear All,
Someone gave me a used Beosound 1 as a gift without remote control, just wondering if Beo1 can be used to control all functions of the Beosound1?
Regards,
Bouncer
The Beo1 remote was originally made only to work with the Beovision 1 / Beocenter 1 televisions.
There is a thread in the old forum http://archivedarchivedforum2.beoworld.org/forums/p/29071/229093.aspx#229093 about how to make it work with other products.
Unfortunately it seems like it will only work with televisions. On the other hand there is no source buttons so it would not be possible to switch between radio and CD.
