Re-install Beovision 7
This post has 5 Replies | 0 Followers
stephen290361
Posts 3
stephen290361 Posted: Mon, Jan 13 2020 2:47 PM
HI, need a little help just re-installed by BeoVision 7 after 18months in store. Just having a little trouble with the power link and speaker connections.
Have connected Sub and Beolab 10 centre speaker as stated.
2 link I have connected to left front 6000 speaker and 3 to right front 6000 speaker. When I turn on tv left comes on but right stays off. when I go to set up I get white noise and can only assign the right to surround. speakers are set L and R?
Razlaw
Posts 4,345
Razlaw replied on Tue, Jan 14 2020 12:25 AM
That is a strange problem. Just tried the settings on my BV7 and do not see anything like that. The only thing I can suggest is to try a different powerlink connection and see if there is any different result.
lawrencejmcook
Posts 742
Hi Stephen,
Find the menu option for speaker roles. You should be able to set one BL6000 to FRONT LEFT and one to FRONT RIGHT.
Lawrence
stephen290361
Posts 3
Thanks for quick response. I have linked right direct to left and it works will swap cable and see if its the cable playing up as would like to get to the bottom.
stephen290361
Posts 3
When I go to assign it only lets me set the right speaker as a Right Surround (R/S) no other options come up not like the left which you can assign L/F, L/S
Razlaw
Posts 4,345
Razlaw replied on Tue, Jan 14 2020 5:04 PM
That sounds to me like perhaps something is wrong with the BV7. You said you linked right direct to left and it worked. If you meant you daisy chained them, did that allow you to properly assign the speaker roles?
Page 1 of 1 (6 items) | RSS
