BM5 Windows Administrator Password
lolli998
Posts 28
lolli998 Posted: Sun, Jan 19 2020 5:51 PM
Hello,
I have a problem with my BM5. When I turn it on, it goes on the Windows XP embedded login page with "administrator" but I don't know the password. I tryed the default ones like admin or administrator or password but nothing worked.
Do you have any idea how to solve this problem?
thanks!
frog
Camberley UK
Posts 624
frog replied on Sun, Jan 19 2020 10:55 PM
Fastest and easiest is to attach a usb keyboard to it and choose the rebuild option on startup. It won’t delete the E: derive where your content is.
lolli998
Posts 28
lolli998 replied on Mon, Jan 20 2020 7:42 AM
I thought about that. the only problem is that I also have a BV Avant connected to it and I'm not sure of being able to configure it again as it is now.
lolli998
Posts 28
lolli998 replied on Sat, Jan 25 2020 1:16 PM
I solved the problem by doing the recovery and set again all the system.
Beheit
Posts 19
Beheit replied on Mon, Nov 30 2020 11:40 PM
Hi
Did you loose all your music by doing so?
Wild Ruedi
Zürich Switzerland
Posts 102
trying to solve another problem I have restarted my BM, also reboot from backup, several times and the stored musicis is not lost. But the radiostation list is empty, when you boot from backup. I have not found a way to avoid this.
Regards Ruedi
BeoVision11, BeoVision10, BeoSound 5, BeoSound 3500, BeoLab 9, BeoLab 4, BeoLab 6000, BeoLab 8000, BeoSound 3200, Beosound Moment,NL/ML converter, delaybox, var.BeoPlay Speakers
hfinette
Posts 34
When you do a recovery you will not loose your music...
Page 1 of 1 (7 items) | RSS
DigiCert Secured Site Seal
