Hi
I just got wheel remote for essence I hear that its possible to pair it with an iMac (Bluetooth)
i don't have any luck with it the manual don't say anything so maybe some in here know how
All the best
Brian
The user guide is a bit vague but this is definitely possible: I did this with my Windows 10 computer.
To enter pairing mode, hold down the top button on the remote wheel (pressing the unfilled circle that looks like an O) for about 10 seconds. When the remote enters pairing mode the pairing light comes on, but you probably won't see it because your finger is over the light you are tying to see.
Anyway, once the light is on you should then be able to see the remote as available for pairing with your Mac: just pair with it like pairing to any other Bluetooth device.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2 Integrated: 1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6 Control: 16x* Essence Remote • 1x Beoremote Halo
* Yes, really! 🤦♂️
What would you use a Essence Remote for on your mac?
Find me on YouTube : Bang & Olufsen Teknisk Forum : https://www.youtube.com/c/BangOlufsenTekniskForum
Thx
Volume and what ever posible for now looking forward to test it
thx Again
