Beomaster 6000 Typ 2251 tuning balance issue
ALF
AUS
Posts 1,015
Silver Member
ALF Posted: Mon, Jan 20 2020 8:56 AM
Hi All,
finally took some time to check out a couple of issues on my BM6000:
first replaced the bulbs for the tuning balance indicators and verified the light intensity balance = ok
checked the upper and lower tuning voltage = ok
so far so good, but I noticed those balance indicators never change while tuning  in a station ??
meaning something is not right ?!!
can someone give me a pointer where else to look for a possible culprit ??
the other question I am trying to figure out is:
how do I get the uP board (board #2) out without dismantling the volume assembly (pullies & string) ???
how else would I be able to get to the display modules for repair ???🙄
as always, thank you so much for your assistance 🙏
ALF
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Wed, Jan 22 2020 11:43 AM
No one ???
well, i wonder how crucial it is to replace the tuning balance bulbs with the Exact Specified (6V, 80mA) bulbs in order to achieve the working balance indicators ??
they are difficult to find - all I could find were 6V 60mA bulbs !
the tuning imbalance shows at 8IC2 pin 7 & 10 depending on frequency being either too low or too high.
that should also result in a voltage variation at 6IC1 & 2 ?! But it doesn't !
dies that make sense ??
ALF
Sehrbug
Posts 15
Sehrbug replied on Wed, Jan 22 2020 12:30 PM
Hi ALF, I had the same issue because the light bulbs I was using was 6v 1W.
I replaced them with
https://uk.farnell.com/cml-innovative-technologies/01143800/lamp-bi-pin-t1-6v-0-69w/dp/1139288?st=light%20bulb%206v
and all working perfectly now.
Vitaly
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Jan 22 2020 3:04 PM
The lamps are critical (which is also why it won't work correctly with LEDs).
I stock the correct lamps for the tuning discriminators.
Also for the volume dial illumination (which are different from the tuning lamps).
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Thu, Jan 23 2020 4:19 AM
Thank you Martin and Vitaly, much appreciated.
I asked that last question as I remembered a similar issue on a BM2000 and its Stereo indicator bulb !!!
so, the suspicions were there.
I will replace the bulbs with the specified one as soon as they have larrived.
what remains is the question of
'how to take out board #2 without undoing the cord of the Vol Pot assembly ??'
the cord (string if you prefer) is attached to a metal pointer and and indicator foil. I can't imagine it should be detached from that ?!!
not much point in doing a "half recap job", isn't there ?!
regards
ALF
Dillen
Posts 13,191
Dillen replied on Thu, Jan 23 2020 6:51 AM
Normally you don't have to take out the display board.
You can access the solderside when the Beomaster is open, and you can access the component side by taking off the glass panel.
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Thu, Jan 23 2020 12:05 PM
Yes, just remembered you can take off the control panel, open the uP box where you get to the two caps 220u and 47u.
thanks Martin for the memory trigger 😁🤙
ALF
Page 1 of 1 (7 items) | RSS
