I am hoping that another member will be kind enough to share with me a pdf version of the full service manual for my Beogram 4002 Type 5504.
I have not been able to find a pdf copy on-line.
Thanks for your help and I can send anyone that can help my personal email.
Tim
I believe the Beogram 4002 Type 5504 (GB) is pretty much the same as the 5503 (USA). They came out the same year (1974) according to the Beoworld Product Information Guide. I haven't seen a specific service manual for the 5503 but the Beoworld Product Manual library has the insert for the 5503. It goes with the 5501/5502 service manual.You need to be a Beoword Silver Member or higher to access the manuals. Easily worth it in my opinion.
-sonavor
Many thanks for the reply and I will download the manual you suggest. Luckily I am a silver member.
Kind regards
