Hello all,
I was wondering if any of you has ever swapped a tv tuner on a beovision 7. I have a beovision 7 40 the bluray version but the tv tuner has no mpeg-4 decoding capability. I believe that later there was a tv tuner with mpeg-4 capability available but I not at all sure if it can be swapped with the old one. Has anyone experience or knowledge of the matter?
Thank you
Tasos
Hi Tassos,
I think it is doable as I have done it in the past with my BV7-32. Check with Nikos and George from B&O service in Athens. Hope this helps
Dimitris-
Thank you Dimitris!
