Hi guys,
I am a new fan into the Beo world and as such I started making plans of buying a Beo turntable. Since the one I read about the most (and also like the most, even purely from a designer perspective) - Beogram 4002, is too expensive for me at this moment (but working on that), I started pointing some more affordable models (also as brands). Recently I found a Beogram 2200 with MMC 20 E cartridge on a very good price (100€). By the images it also looks in a very good condition. I couldn't find much comments or reviews about that model until I encounted this website. But still my question is: does it worth buying? Could you please tell me what should I consider when choosing a Beo turntable? Any additional info is much appreciated.
Thank you in advance.
So nobody could help me out here with some experiance sharing?
dainsane:So nobody could help me out here with some experiance sharing?
Well... Jacob Jensen did his work.
In general Bang & Olufsen never produced a bad record player.They are all great decks in their own respect, for their cost, age etc.
Beogram 2200 was made to suit Beomaster 1900 and 2400 design wise but will work with all of the 1970s and 1980s Beomaster models.There are better Beograms, but also costlier, and with a good needle it will provide excellent performance, even when using better amplifiers than the above mentioned.
I have a friend that used one for years when it was a new product back in the day. He never had a bad word to say about it, so I'd say it'd be a fine table.
Jeff
Thank you, guys!
As I mentioned my final goal is Beogram 4002. It is my favourite.But for now I would stick to a lower cost range. Still sound quality maters to me
Contacting the guy that sells it, it turned out there is some strange noise when playing the table. He described it "like a current buzz", like some cable is not attached well. He said that he checked it few times connecting it differently - buzz stays. Could it be because of dust collected through time? Or it is really a cable? Or else?
dainsane:Thank you, guys! As I mentioned my final goal is Beogram 4002. It is my favourite. But for now I would stick to a lower cost range. Still sound quality maters to me Contacting the guy that sells it, it turned out there is some strange noise when playing the table. He described it "like a current buzz", like some cable is not attached well. He said that he checked it few times connecting it differently - buzz stays. Could it be because of dust collected through time? Or it is really a cable? Or else?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hi again,
Here is an update from my side and a new question:
I have checked the Beogram 2200 mentioned at a restoration shop - all parts were in good condition except for the stylus which needed a retipping. Since the price of the turntable was good I bought it with the idea to send the cartridge for retipping in a shop in Berlin (I also live in Germany so that works for me).
Before I send it I found a second Beogram 2200 with stylus in perfect condition at ridiculously low price - with broken lid, without the veneer on the sides and a really terribly replaced DIN 5-plug with cheap RCA plugs. I thought "perfect for spare parts, especially when the cartridge is working". Bought that one too.
Now I have a working turntable with MMC 20 E cartridge that sounds great and looks perfect next to my Philips CD303 and Pioneer SA 506.
Recently from time to time the speed goes faster on start (I switch it to 45 then again to 33 and it normalizes) or have problems when playing records on 45 rpm. My thought is that the belt needs to be replaced. Please advise if this could be the case. If yes, should I go with the belt I see on Amazon ( https://www.amazon.de/-/en/gp/product/B014M5CVBO/ref=ox_sc_saved_title_1?smid=A1DW1HKCVIU0T1&psc=1 ) or better to be safe with one from https://www.beoparts-shop.com/product/platter-belt-2/ ?
Thanks in advance.
