Beomaster 3500 Touch panel problems?
rogersittard
Posts 10
rogersittard Posted: Thu, Feb 6 2020 8:02 AM
Hello,
I have an old beomaster 3500 with Touch panel problems.
All works perfect ,only the AUX,GOTO an STORE works anymore.
What can i do to fix this Problem.
I can not use the tuner now,can not tune stations!
I Hope anybody can help me with this problem,
Thanks,
Greetings Roger
loureed5
Posts 171
loureed5 replied on Thu, Feb 6 2020 10:26 AM
Hi Roger,
The 3500 was  less expensive than it's brother : the Beomaster 4500.(which I have)
Based on my experience, I would ask you :Is the glass panel secured? Loose at all?
My glass panel succumed to the passing of time, and came off completely.And what it did reveal was
all the programme buttons,which responded to a light touch and all worked perfectly.
Despite many attempts I couldn't put the glass panel back on,so it's off to the service centre.
(It's a common problem evidently).
Essentilally. the glass panel has to be located just above the buttons to respond to "touch control functions. "
Hope this helps
regards
Noel.
Steffen
Denmark
Posts 1,408
Steffen replied on Thu, Feb 6 2020 11:01 AM
It's a common problem that the glass panels become loose, as they are mounted with double-sided tape to a plastic frame.
It is no big job to glue them back in place (just a bit messy to clean off the old tape) Wink
You can use some new (thin) doublesided tape - or some super-glue.
Have a look at this thread:
https://archivedforum2.beoworld.org/forums/p/2159/21943.aspx#21943
rogersittard
Posts 10
Thanks for your replay.
i can try this,remove the old tape and fix it with new tape.
when i remove the Glass plate en touch the sensors it works!
with glassplate on its Place,No function,even when i press down te plate on its Place......
the sensors touch the plate corectly!!!
rogersittard
Posts 10
rogersittard
Posts 10
rogersittard
Posts 10
Yes the glassplate is completly loos at all!
rogersittard
Posts 10
Sorry my Answer did replayed Serveral times!
Spassmaker
North Germany
Posts 223
Hi Roger
When you come to clean the Glass Plate, be aware to juse NO Alcohol or other Solvents like Acetone or Colour Thinner, your Paint on the Backside comes of in Seconds. The Labeling on the Fronside too.
To remove the old Glue take NO scraping Things, just a small Brush and some Label solvent that smells like Orange like Konakt Solvent 50.
Be patient to become succsessful.
Best Regards Christian
Page 1 of 1 (9 items) | RSS
