Newbie : how to connect Beocenter 9300 to Beovision 7-55 ?
This post has 14 Replies | 1 Follower
Bzguy
Posts 18
Bzguy Posted: Fri, Feb 7 2020 4:18 PM
Hi all, it took some tim, but I finally managed to get my first B&O equipment : a beautiful Beocenter 9300 with a pair of Beolab 8000 speakers.
All works fine, but now I would like to buy a Beovision 7-55, including a Beosound 7.2 speaker.
Question now : how can I connect all devices so I can always use my speakers ? For TV as well as for Beocenter ? For TV, I would like the 7.2 as "center speaker", and the 8000's as L/R.
When using the Beocenter, I would like the 8000's as L/R speakers.
Bzguy
Posts 18
Bzguy replied on Fri, Feb 7 2020 5:12 PM
Thank you for your answer : you're right : Beolab 8000 is powerlink, connects this way to the Beocenter 9300.
See photo here, this is how the back of a Beocenter 9300 looks like :
However, as I don't have a Beovision 7-55 yet, I do not know how the connections look like there, so i'm not sure how I could connect the Beocenter 9300 to the TV.
Many thanks, it took some time to get some nice equipment (and I found a complete Beosound Century as well !) , as all good things in life ... ;)
Bzguy
Posts 18
Bzguy replied on Fri, Feb 7 2020 8:22 PM
Many thanks for your replies, thanks for the added information, hope to get a 7-55 by the end of this month (but since I'm in the process of moving from Belgium to France, it'll stay in Belgium for a while, moval is foreseen end of May)
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Feb 7 2020 9:44 PM
Bzguy:
... i'm not sure how I could connect the Beocenter 9300 to the TV.
BV7 has Masterlink, whereas BC9300 has Master Control Link.
Hence:
-  Beolab 8000s should be connected to BV7, as previously advised.
- A Beolink Converter Type 1611 is required to connect the BC9300 to the BV7, with the following connections (assuming TV and BC are in same room)
- Masterlink Cable from TV to Beolink Converter.
- Audio Aux (7-pin cable) from BC9300 TV/AUX socket to Beolink Converter
- Powerlink Cable from either BC9300 Powerlink socket to Beolink Converter
- Mains power cable to Beolink converter
- TV should be set in V.OPT 2.  BC9300 in A.OPT 0 - hence all IR/remote control will be via the TV.
papas_spiros
Posts 24
Please for your advice on how I can connect 6 speakers to my BV 7-55 MKII. (I have not install it yet).
2 front (Beolab PENTAS) 2 back (Beolab 8000) and 2 Beolab 3s in the "middle".
+ sub (Beolab 2) + Beolab 7-2 center.
Asking since the TV at the back has 5 powerlink connections (not 6)
+ 1 for the Sub + 1 for the center.
Thank you all in advance.
beopaul
Posts 83
beopaul replied on Thu, Apr 8 2021 7:23 PM
Guy:
I’m pretty sure BC9300 is also Masterlink. The BC9500 which came before it was Master Control Link.
Johan
Bolsward, NL
Posts 450
Johan replied on Thu, Apr 8 2021 8:14 PM
papas_spiros:
Hello Papas_spiros, as the PowerLink cables carry two signals (normally L+R) it is possible to connect two speakers to one PowerLink socket. This can be done by using a splitter or by daisychaining two speakers (when they have two PowerLink sockets - beware, the 8000s only have one).
Make sure that of the two speakers connected to one PowerLink socket of the BV, one is set to R and the other to L. You can then later in the menu assign the roles to each speaker (front L&R, surround L&R, rear L&R) and set their volumes and distances.
Hope this helps! Johan
Daniel
Svinarp, Sweden
Posts 1,632
Daniel replied on Fri, Apr 9 2021 7:18 AM
beopaul:
No, BC9300 is MCL. A converter is needed.
https://www.beoworld.org/prod_details.asp?pid=411
Johan
Bolsward, NL
Posts 450
Johan replied on Fri, Apr 9 2021 8:54 AM
Johan:
papas_spiros:
And it could very well be that the 'CENTRE 1' PL connection can also just be used in the same way as the 5 others, making six available in total. Good luck
papas_spiros
Posts 24
Much appreciated Jordan.
I will try your clearly described steps.
Thank you!
Spiros.
papas_spiros
Posts 24
Thank you!
Spiros.
Page 1 of 1 (15 items) | RSS
