Beomaster 2400 front/back balance control
This post has 3 Replies | 0 Followers
Mark2020
Posts 12
Mark2020 Posted: Tue, Feb 25 2020 6:06 PM
Hi there. I have a beomaster 2400 and am adding two beovox p45 to the rear of my room on the second speaker connectors. I feel like the p45 are a little overwhelming at the same volume of my s120s in the front. Is there a way to reduce one set of speakers in volume relative to the other set? Thanks!
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Feb 26 2020 9:28 AM
Hi Mark,
Unfortunately the speakers are wired in parallel internally, and are designed to be used in separate rooms, so the only simple thing you can do is turn Speakers 2 on/off using the little switch.  (Or you could turn Speakers 1 off by inserting a headphone jack.)
Two more complex solutions:
- Run a line level output from the tape socket and use a separate amp for one of the pairs of speakers.  Unfortunately you would not be able to control the overall volume together using the remote (as the line level is fixed)
- Attenuate one of the speaker pairs using something like this. https://cpc.farnell.com/monacor/at-62st/high-power-l-pad-stereo/dp/LS00548?MER=sy-me-pd-mi-alte
Others on the forum may have other solutions.
Mark2020
Posts 12
Mark2020 replied on Wed, Feb 26 2020 5:15 PM
This is one solution I was thinking might be possible, having a volume control for the second set. Would this go between the amp and the speakers directly on the speaker wires? Also, would I need one for each speaker or does this work for the set?
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Feb 28 2020 1:03 PM
Mark2020:
That would go between the amp and one of the sets of speakers, and it's stereo so you'd only need one for the set.
Page 1 of 1 (4 items) | RSS
