Hi all,
I have recently bought a Beomaster 4500 and have issues, tuning and presetting radio station.
I'm following the steps in the manual but seem to get stuck on the TO GO button it's just not reacting to anything. Am I doing something wrong? after holding the programming button the TO GO and STORE controls appear on the display (green) but somehow these controls do not react if i tosh them!?
Hoop someone can tell me how to fix this.
Best Regards.
Pages 13-14-15
https://www.bang-olufsen.com/~/mediaV3/files/user-guides/singles/BeoSystem4500_UK.pdf
Hi Willem,
I have had some trouble with my 4500- the glass panel detached, and functions did not respond when I touched the control panel.
Without the panel I could access the touch sensor controls.
Even if your glass is not detached, maybe it's loose , and preventing the glass from touching the touch sensors for GO TO and STORE. ?
regards
Noel.
Thank u Noel,
Found the same here the glase is loos that was the issue.
Glad to help out- I forgot to mention that the glass panel is only held in place by double-sided tape,so it's only a matter of time before the glass becomes loose or detaches completely.
