Beogram 1500, 5714 P3 too fast
Slask73
Posts 3
Slask73 Posted: Thu, Feb 27 2020 7:05 PM
My inherited Beogram 1500 5714 P3 is spinning at about 36,6 according to a rpm app. Of course there is a slight chipmunk feel when playing records.
I have replaced the belt with a correct one, treated it with lubricant, but it still plays too fast. Is there anywhere on the player I can adjust the pitch of the speed ? I have not been able to find a manual, and there is no obvious switch. Any tips ?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Feb 27 2020 8:29 PM
Speeds are adjustable through small holes in the bottom plate.
The speed setting trimmers could also be bad.
Slask73
Posts 3
Is it possible to guide me a bit where these holes are ? Do I have to take it all apart or is this reachable by just removing the disc ? I attached a photo  in case it could help
Slask73
Posts 3
Slask73 replied on Fri, Feb 28 2020 6:31 PM
I actually found it myself while looking at the picture I took. There is a regulator wheel right above the operating panel :) So now I have 33,6 rpm which is much better
Dillen
Posts 13,191
Dillen replied on Sat, Feb 29 2020 6:39 AM
Actually, I think you can reach the trimmers through the two small holes under the platter.
They look like this inside:
https://beoparts.com/2014/08/14/beogram-motor-control-circuit-board-pcb-8005023/
Page 1 of 1 (5 items) | RSS
