I've gone wired not WISA with my BL18/19s
This post has 17 Replies | 2 Followers
Duels
England
Posts 2,553
Duels Posted: Fri, Feb 28 2020 1:12 PM
I bought my BL18s about 4 years ago and added a BL19 about a year ago.  I've always used a Transmitter 1 to connect using WISA.  Yesterday I decided to use cables to connect them to my Core - Thanks Steve@ who got them to me within a couple of days.
I hope others may find the information below useful/interesting if they have some of the issues and thoughts that I have had.  The background to this is as follows:
My experience with WISA has been patchy to say the least.  When I just had the 18's they would generally start up ok albeit with a 20 second delay whilst the transmitter fired up and did its thing.  Adding the 19 made the start-up process less reliable.  The speakers could turn on and off several times during the start up process and occasionally everything needed to be powered off and on again - naturally this would happen when I was demo-ing to friends. I could work around this by just playing through the 18s at first then turning the 19 on (and flicking the 2.0/2.1 switch on the transmitter) but this was hardly an elegant solution.
Furthermore, at least once a day one of the speakers would lose its WISA connection and turn off and on again after about 10 seconds.  Whilst WISA worked well about 99% of the time the other 1% got pretty annoying.  I did try all the recommended fixes and moved other wireless devices etc etc but could never establish a flawless WISA experience.
From a sound point of view (as mentioned by others on another thread) I felt the sound processing between the 18s and 19 which is done by the transmitter left the mid-range somewhat weakened compared to using the 18s on their own.  Adding the sub made a real difference to the sound above about 60%-70% of maximum volume but to be honest I never really play at that level unless I'm showing somebody how the speakers sound played loud!  Below that sound level I preferred the 18s on their own with the stronger mids.
I'd always wished their was some way of keeping the 18s as they were but adding a little more depth to the low bass i.e. trying to find that low down rumble below the range that the 18s can go.
So I ordered a couple of cables from Steve@ and daisy chained my speakers as follows: Core>BL18>BL18>BL19.  There's no automatic high/low pass filters with this set-up.  With the transmitter I believe it is around 120Hz.  So I turned the BL19 low pass filter "on" and set it pretty low (about 50Hz from a possible range of 40-160).  I believe the BL18s go down to about 40Hz.  I simply used a lot of trial and error to find a level where the bass wasn't overwhelmed and only seemed to extend the range downwards.
I was prepared for the sound to be horrible but it isn't.  I actually like it more than when I was using the transmitter and the inbuilt sound processing.  After playing around with the LPF filter on the BL19 the sound is exactly as I hoped with the 18s sounding as fantastic as they did on their own with a bit of oomph at the very bottom of the frequency range below 40Hz. Obviously there is a trade off at very high volumes where the ABL kicks in on the BL18s and the BL19 isn't compensating for anything above approx. 50Hz but that's would be the case in any event with the 18s on their own and, as I said earlier, I rarely use them that loud as I live in an apartment and quite like my neighbours.
I will of course accept that sound is a personal thing but I can't think of any technical reason why what I've done is wrong (extreme audiophiles who employ gold-plated pixies to hold their cables off the floor will probably have some views).  And £2,500 might be a lot to have paid for a bit of extra oomph but I don't care about that because I like having a BL19.  The speakers sound great to me and I have eliminated those pesky WISA drop-outs.  Its also nice to have things start up instantly without the WISA delay.
Like some other folk I guess I cut B&O a bit more slack than I would other manufacturers when it comes to idiosyncrasies of their products.  I cant really explain why but its probably because their stuff looks so good and I love owning it.  But it is really nice to think that when I'm showing my stuff off in future it will start up cleanly and all speakers will carry on playing for 100% of the time.
Mikipidia
Posts 2,169
Mikipidia replied on Fri, Feb 28 2020 1:28 PM
Yes - thumbs up
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Fri, Feb 28 2020 2:11 PM
Thanks for sharing!
I’ve all speakers over Wisa and no problems guess I’m lucky
Regarding the midrange / bass of 18/19 combo I have same sort experience. With my BV I can alter a lot of parameters and I’m in the process of finding the ideal tipping point of bass/midrange to the BL18’s and the oomph to the BL19, both on lower and higher volumes. My search is the sound of the Eclipse with the oomph it has on its own on low volume, to be able to have same sound signature on high volume and then over the BL18/19. It is a search for ideal speaker positioning, settings and tweaking!
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Duels,
Thanks for this, glad to have been of service! Yes - thumbs up
WiSA has its place as a convenient way to get music when cables can't be fitted, but running a wire to each speaker is the best option for sound quality and reliability Whistle
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Jaffrey2230
Washington DC
Posts 520
Interestingly one of my friends who tried to switch from a pair of wired KEF LS50 to the wireless KEF LSX ended up switching back to wired mode for the LSX because of connectivity and lag issues. Back in the day I tried to set up a pair of Devialet Phantoms in stereo pair and that too was too unreliable. In theory it sounded great but never worked reliably enough. Interestingly the only wireless stereo in my home that works with no delay and every time is my pair of HomePods.
I do agree that B&O design is probably why some keep them despite the issues. I too am usually much quicker to sell other gear vs B&O. However, recently, their newer Beoplay and Beosound wireless products work really really well.
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sat, Feb 29 2020 7:21 PM
We all have different WISA experience, mine is very satisfactory since more than 5.5 years.
WISA products SW update + product placement + disabling 5 GHz WiFi have helped drastically: very reliable, no drops so ever.
Millemissen
Flensborg, Denmark
Posts 14,680
It is rather important that all WiSA components are updated to the latest sw.
Jaffrey2230
Washington DC
Posts 520
Wouldn’t disabling 5HZ WiFi drastically reduce WiFi performance for other devices in your home is is it something you can do specifically for the BL18?
B&O in my life 😊:
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sat, Feb 29 2020 10:15 PM
Jaffrey2230:
No significant impact to be honest, having good 2.4 GHz spots and a good wireless network coverage is sufficient for my day to day usage, as well as for all my wireless connected products, B&O products included.
Apple WiFi 5 GHz spots were intrusive, it is possible that other brand would coexist better with B&O Wisa products which by the way are supposed to coexist well according to the documentation ....
Placement is also very important, Transmitter 1 particularly.
poodleboy
Posts 303
poodleboy replied on Sat, Feb 29 2020 11:30 PM
Millemissen:
How do you do that without dealer support?
Jaffrey2230
Washington DC
Posts 520
🤷‍♂️ I’d rather keep 5HZ WiFi and live with wired BL 18s vs downgraded WiFi to 2.4 GHZ to keep wireless BL 18. I personally would not be able to live with it.
B&O in my life 😊:
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Mar 1 2020 8:21 AM
poodleboy:
If you have a Transmitter 1, or if you can borrow one, you can do the sw updates by yourself.
Fansastic
Posts 768
mbolo01:
If you have a Transmitter 1, or if you can borrow one, you can do the sw updates by yourself. BS Moment, BS Core, BG 4002, BC 4500, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
Do you know where I can check software versions of my BL18 and BR1’s? Tried with my Eclipse but not clear where to look. Thanks!
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Mar 1 2020 10:07 AM
Fansastic:
I only know the Transmitter 1 way which you can find here: https://www.bang-olufsen.com/fr/product-support/accessories/beolab-transmitter-1
Duels
England
Posts 2,553
Duels replied on Sun, Mar 1 2020 12:32 PM
What would be nice is to have a way of adjusting the sound processing for the BL18/19 combo without using the transmitter with wired speakers. I don’t have a BV. The BL19 has low pass filter adjustment so it would just required High pass filter adjustment for the BL18s I guess.
Duels
England
Posts 2,553
Duels replied on Mon, Mar 2 2020 10:32 AM
Steve at Sounds Heavenly:
Well reliability-wise it has been nice not having to experience dropouts over the weekend.
As for sound quality I’m going to spend a bit of time listening seriously hard to tracks I know particularly well.
Bring on my “speaker test” spotify playlist and never-ending cups of coffee.
355f
cambridge/london
Posts 119
355f replied on Sun, Jul 26 2020 3:48 PM
BL20 connected via WISA to Avant 55, when setting a speaker group which turned OFF the BL20 and just using the internal speakers, the logo on bl20 would stay lit, even though there was no sound - other than a very faint hiss.
Ive just wired them, now, when selecting TV speakers only no illuminated  bl20 logo which is how it should be.
There is not supposed to be a difference in sound ..... but.i think it sounds fuller
355f
cambridge/london
Posts 119
Page 1 of 1 (18 items) | RSS
