Hello.
We have inherited a Beosound 9000. After some years i want to sold it, but the Beosound is secured with a Pin-Code which i dont know.
I know i can get a Master-Code from B&O, but i need the serialnumber of the Beosound. The problem is, there is no serialnumber. Some "specialist" has removed the ident plate.
Is there another place, where i can found the serialnumber`?
Thanks,
Klaus
https://archivedforum2.beoworld.org/forums/t/17320.aspx
THX but i didnt found the shift key on the Beo4?
got it, thx
