Hi!
All light commando works perfectly when beov 11-46 is in use. Once I turn it off, I cannot forward Light-commandos to Beolink Gateway.
I have turned off all powersaving I can find (Audio and Video), not sure where else to search so I taking my chances to ask the question here.
In Customer Service Menu I cannot find any more to check, it is connected to my Beolink Gateway so it should be ok there..
Does anyone have an idea or experience of this issue?
Problem solved by local B&O dealer. Thanks for them!!
Was the problem quickstart timer related?
//Alex
BV14, BV10, BeoGram 3000, 4500, BS 9000, Moment, Core, Ouverture, Essence, Beo6, BROneBT, BeoTime, ML/NL, BLGW, BeoLab 2, 11, 18, CX100, BeoPlay A6, M3, E8/H3/H8
Yes, I needed to set quickstart on all days 00:00 to 23:59.. All works fine now..
