I have been given the Audio Technical LP120XUSB turntable as a present. I tried to connect it to my Overture on the AUX port but it did not work. Is there a way I can connect it to the B&O Overture?
With what did you connect it?
//Alex
BV14, BV10, BeoGram 3000, 4500, BS 9000, Moment, Core, Ouverture, Essence, Beo6, BROneBT, BeoTime, ML/NL, BLGW, BeoLab 2, 11, 18, CX100, BeoPlay A6, M3, E8/H3/H8
I used a B&O AUX port to 3.5mm jack male connector to connect to a 3.5mm female to RCA for the turntable.//Pradeep
