How to open back cover on Beosound 8 ?
This post has 4 Replies | 0 Followers
mainmike
Posts 5
mainmike Posted: Sat, Mar 7 2020 12:31 PM
My Beosound 8 wont work anymore, so i decided to take a look inside it myself, but i dont see how to get the back cover off. I remove 6 screws, what else to do?
(..and also, what to look for when open?)
leosgonewild
Helsinki, Finland
Posts 2,373
Start from the front.
leosgonewild
Helsinki, Finland
Posts 2,373
What isn’t working?
mainmike
Posts 5
It wont turn on, no green light.. used to work fine before i moved.
leosgonewild
Helsinki, Finland
Posts 2,373
Connect a source that is playing to the rca input and do some random button pressing g for a while on the front panel. Usually does the trick.
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
