BeoCenter 2000 needle
critterbeach
Posts 4
critterbeach Posted: Fri, Mar 13 2020 4:06 AM
Hi Team,
My BeoCenter 2000 has lost its needle. Wondering how I can get it up and running again? Is there an unofficial  or official part I could replace it with? And do I need to replace the whole stylus or is there a needle that I can purchase and insert?
Regards,
Michael
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Mar 13 2020 6:06 AM
You have two options;
- Take a chance on a used cartridge.
- Send your cartridge in for retip'ing.
Where are you?
critterbeach
Posts 4
Thank you for your response. I am in Australia.
critterbeach
Posts 4
critterbeach
Posts 4
Do you know if it's possible to connect something like an Ortofon stylus to it?
Dillen
Posts 13,191
Dillen replied on Sat, Mar 14 2020 6:57 AM
critterbeach:
It has been done on tangential decks, but it's not easy. Dimensions, angles, contacts and signal levels are all different.
It would require a complete rebuild of the tonearm and counterweight and some modifications to the preamplifier.
Also keep in mind, that modifications usually affects the value. Bodged B&O is generally worth very little.
Page 1 of 1 (6 items) | RSS
