Hi guys, new member here!
I'm seeking a little advice if I may.
I have a 3.1 setup with Avant (centre), 2xBeolab18 (front left & right, wireless) and 1xSVS sub (RJ45 powerlink to RCA).
It's awesome!
I've recently acquired a couple of Beolab 3's so I can go to 5.1. I already had a "receiver 1" so my plan is to run both Beolab 3's from the powerlink on the "receiver 1".
As I'm in Australia and I have no patience to wait for international deliveries, I've made a powerlink cable RJ-45->Mk3 DIN.
I've set up a new speaker group for testing so I can temporarily exclude all the other speakers.
So I plug the 3's into the RJ45 powerlink on the "receiver 1" - green lights on the speakers! So far so good. (I know the "receiver 1" works ok because I was using it for the sub channel until recently).
Here come the questions….
thanks in advance :)
andy
c310r:Hi guys, new member here! I'm seeking a little advice if I may. I have a 3.1 setup with Avant (centre), 2xBeolab18 (front left & right, wireless) and 1xSVS sub (RJ45 powerlink to RCA). It's awesome! I've recently acquired a couple of Beolab 3's so I can go to 5.1. I already had a "receiver 1" so my plan is to run both Beolab 3's from the powerlink on the "receiver 1". As I'm in Australia and I have no patience to wait for international deliveries, I've made a powerlink cable RJ-45->Mk3 DIN. I've set up a new speaker group for testing so I can temporarily exclude all the other speakers. So I plug the 3's into the RJ45 powerlink on the "receiver 1" - green lights on the speakers! So far so good. (I know the "receiver 1" works ok because I was using it for the sub channel until recently). Here come the questions…. The Beolab 3's make sound… but *very* quietly and only from the tweeters. I'm getting nothing from the woofers. One's set to L and one to R, and I've set them both to "wall". Is there anything in my Avant setup that could cause this? Could it be cabling? As I'm using "receiver 1", I tell the Avant that WPL3 is "BEOLAB3". WPL (as all powerlink) can carry stereo… but when I look at the speaker roles I see "BEOLAB3" but have to set "left surround" or "right surround". I want that powerlink to send both the surround channels so the 3's can do L and R properly… how's this done? thanks in advance :) andy
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Ah, understood re the receiver - thanks for your replies. I'll hunt for another one :)
Still weird how I get nothing but treble from either of the BL3's.
I've tried connecting one and setting it to "front left" - green light and music but no woofer.
Wondering if I got my cables wrong I made a 3.5mm jack to DIN cable to see if my ipad would send a different signal.
I took the 'trigger' from a breakout on the powerlink and combined the grounds - green light on the speaker.
Plugged 3.5mm into ipad - same result :(
Beginning to wonder if I have a fault in the units... but both of them??
I think the next step is to get them looked at.
I'm getting pretty good at patching cables :)
Ok just connected both BL3's to PL4. Green lights on the speakers.
Avant is happy (doesn't say 'missing') and i get a faint white noise when scrolling through speaker connections.
Created a speaker group just for the BL3's and assigned front left and right.
I'm getting stereo music from the BL3s but only out of the tweeters.
Many thanks Lawrence.
I have someone coming round tomorrow with a 'known good' speaker so that'll prove whether it's my cables or not. Hoping it is!
As a completely separate cable test I created a female DIN to 3.5mm line in jack so I could do this:
Avant PL RJ45 -> male DIN (unplugged from BL3s) -> female DIN -> 3.5mm jack plugged into PC sound system line in (powered 2.1 Jamo system).
Interesting thing about this is I get full range... BUT it's a *really* low signal that I have to crank to 70%+ on the Avant to get meaningful sound on the Jamo.
Hoping this points to a crappy cable/soldering... will advise :)
thanks again
Update - both BL3 woofers open-circuit :(
On a positive note my cables worked!
Thanks all for your input and stay safe.
