Another option is to use an external USB sound card (like this one: https://soundsheavenly.com/music-input/17-beomaster-5-beosound-5-aux-usb-input-converter-also-works-as-pcmac-sound-card.html ) to connect the speakers, instead of the headphone socket on the Mac, this will avoid the noise when the Mac goes to sleep.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Steve at Sounds Heavenly:Hi, Another option is to use an external USB sound card (like this one: https://soundsheavenly.com/music-input/17-beomaster-5-beosound-5-aux-usb-input-converter-also-works-as-pcmac-sound-card.html ) to connect the speakers, instead of the headphone socket on the Mac, this will avoid the noise when the Mac goes to sleep. Kind regards, Steve. Steve. www.soundsheavenly.com Sounds Heavenly are proud to sponsor BeoWorld!
https://www.amazon.com/Koss-155954-VC20-Volume-Control/dp/B00001P4XH/ref=sr_1_2?keywords=koss+headphones+volume+control&qid=1584354590&sr=8-2
also does the trick. I have a bunch of these as a "swiss army knife" solution for lots of problems like this. I originally bought one to use on airplanes with a VERY sensitive pair of in-ear earbuds that I owned about 20 years ago. I then got a second to put between my AirPort Express and a pair of BeoLab 3's back when the AirPort first hit the market...
Cheers-g
Geoff Martin:https://www.amazon.com/Koss-155954-VC20-Volume-Control/dp/B00001P4XH/ref=sr_1_2?keywords=koss+headphones+volume+control&qid=1584354590&sr=8-2 also does the trick. I have a bunch of these as a "swiss army knife" solution for lots of problems like this. I originally bought one to use on airplanes with a VERY sensitive pair of in-ear earbuds that I owned about 20 years ago. I then got a second to put between my AirPort Express and a pair of BeoLab 3's back when the AirPort first hit the market... Cheers -g
