When I select the Aux input, my Beocenter 9000 turns on and displays "1 2 3 4 and 8" in the preset/track number display. The Aux input works fine and these numbers stop displaying after about 2-3 seconds. I found no reference to this in the original manual. Is this some legacy programming or an error code?
As Lawrence said above but the full list is as follows:
AUX 1 - TV
AUX 2 - V.TAPE
AUX 3 - SAT (or DTV)
AUX 4 - CDV (or DVD)
AUX 5 - V.TAPE.2 (I think this may be BC9500 only)
AUX 8 - MICROPHONE
This functionality enables you to select the above options using the Beocenter's front panel, rather than a remote.
