LCS 9000 IR signal issue
This post has 4 Replies | 2 Followers
Willem0709
Posts 15
Willem0709 Posted: Mon, Mar 16 2020 12:47 PM
Hi all,
A couple of days back I have bought a LCS9000 intended to be repaired.
The owner explained the buttons on the unit function correctly but its not selecting a source to play.
After investigation its clear you can only select a source by using a remote control, I have tried using my Beo4 but its not responding to any thing. I opened the unit and see someone has been welding on the "PCB 5, Display, Keyboard and IR Receiver" more specific:
  • D1 (IR receiver)
  • D2 (welded together)
  • C39 (replaced by new component)
By seeing this I wounder if someone knows if the complete print can be re pleased and where to buy?
Further more if anyone would have some knowledge of these components, and has encounter the same issue?
Best Regards,
Willem L.
Willem0709
Posts 15
Hi all,
I have replaced the following components on the "PCB 5, Display, Keyboard and IR Receiver":
  • C18: 22µF 20% 3,6v (as explained in a different tread)
  • and bought IR recivers SFH235
Now this solved the issue for the remote control however still no sound out of any of the inputs:
  • MCL tested with the IPOD/TV/AIRPORT EXPRESS TO BEOLAB 3500 cable from sounds heavenly (also performed the setup accordingly)
  • MCL connected to Beogram CD 4500.
  • ML connected to a Beosystem 3.
But no sound on any input, is there any known failure that could cause this issue?
Best regards,
69er
Posts 110
69er replied on Thu, May 13 2021 10:13 PM
I have exactly the same issue.
capacitor exchanged, I can switch between cd, radio and so on, but no sound (connected to a Beocenter 2500 with masterlink)
best regards
69er
Beouser66
Posts 47
Beouser66 replied on Fri, May 14 2021 9:57 AM
Beocenter 2500? Do you mean beosystem 2500 ? But this have no masterlink do you you converter ?
69er
Posts 110
69er replied on Fri, May 14 2021 10:25 AM
I mean the ouverture which has a masterlink
The 2500 with the sliding doors
i have 3 beolab 3500 and two of them are not working with the above mentioned symptom
best regards
69er
Page 1 of 1 (5 items) | RSS
