I have updated the B&O Product Software Revision list in the Technical WiKI located HERE
This update is valid up to February 2012
Regards Keith....
The beolink active upgrade, what has it enabled/changed ?
valve1: The beolink active upgrade, what has it enabled/changed ?
Updated to Version 1.5 enabled the A.AUX command
Update to Version 1.6 provided MasterLink Gateway compatibility.
Does the 1.5 update on the Beo Passive also add A AUX to the Beo Passive?
Is there a software update to add A AUX to the Beolab 2000?
Keith Saunders:Updated to Version 1.5 enabled the A.AUX command
Thank's Keith, that would explain why I could not get my sonos to work in my link room.
Hi Keith
Can you clarify something for me please.
I have a beovision 10-40 current build 166, dealer is coming and installing update 224 next time he is in lanzarote.
A few beoworld members who have had this installed say there is a definate improvement to the sound.
HAve they imagined this as technical support in spain informed my dealer this update is for benefit of denmark in production not the consumer .
so my question is what does this software do.
many thanks
malcolm welborn
