System start up for a beginner
This post has 26 Replies | 2 Followers
Aaron Evans
London
Posts 39
Aaron Evans Posted: Sun, Dec 30 2012 10:13 AM
Hello everyone,
I have have just purchased a beomaster 5000 amp,beovox 1000 speakers and a beogram 1600 as a "starter pack", all cheap buys on e bay and have fallen in love with it already. I am looking to better my set up but on a fairly tight budget has anyone any ideas? Also seen a pair of redline 60.2 speakers fairly cheap how much of an improvement would there be between them and the 1000s ?
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Sun, Dec 30 2012 11:20 AM
Crashwhu:
Hello everyone,
I suspect the beovox 1000 speakers might require you to keep the BM5000 volume on the low side!
Search the forum and archived forum for advice on the best matching speakers ( and look for speakers without foam rot if you want to keep your refurbishment work to a minimum).
Also consider the condition of the components you have already bought. Pick the best and look them up on the products page of the main site where you will find the other components that were designed to work with what you have got.
Graham
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Dec 30 2012 12:21 PM
Do you mean a Beomaster 5000, or a Beolab 5000? Either way, the Beovox 1000s can be bettered. I would consider Beovox S45.2 speakers as these are superb sounding and easily available. If you want more bass, S75s are their bigger brother. RL speakers are fine but will need new capacitors as they get very dull with age. RL60.2s are the ones to go for - plenty of power handling and not too big! The original RL60s have an Auxiliary Bass Radiator that rots away and spoils the sound.
Peter
Aaron Evans
London
Posts 39
Thanks for the advice.You are right about the volume even though the wife seems to think it is loud enough. I will keep looking I didn't realise ther is a B&O community out there,thanks for the advice.
Aaron.
Aaron Evans
London
Posts 39
It is a Beomaster 5000. I am trying to build the stack system but keep losing out on e bay I didn't think they would be as much as they are. Thanks for the advice I think I will go for the 60.2 s I quite like the look of the RLs. Would it be a good match with the amp?
tournedos
Finland
Posts 7,357
tournedos replied on Sun, Dec 30 2012 2:49 PM
Crashwhu:
Very much so, but better approve the design with your wife before getting a pair - it's a love or hate thing Big Smile
You can also look for the newer RL6000. They are technically essentially the same speaker but available in a glossy black finish / black cloth combo which usually matches modern decor better.
--mika
Aaron Evans
London
Posts 39
To be honest Mika I really don't think she is too bothered. I think it's quite a modern look for something that age, they must of been cutting edge back in the day. Thanks for the advice. I am finding all this B&O stuff is getting a bit addictive!!!
bidstonhall
Thailand 5560 miles from Struer
Posts 363
you are not alone there
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Sun, Dec 30 2012 3:47 PM
Crashwhu:
Carefull.... we have a name for this condition but no cure.......
bayerische
Ekenäs, Finland
Posts 4,770
It's addictive alright!
Too long to list....
Aaron Evans
London
Posts 39
Sounds like I may have caught the bug does there ever come a time when you are content with what you have instead of constantly trawling through e bay!
Johan
Uppsala, Sweden
Posts 239
Silver Member
Johan replied on Sun, Dec 30 2012 4:45 PM
Crashwhu:
If that's a question, then the answer is no, I'm afraid. Don't despair, though, you're in good company.
Aaron Evans
London
Posts 39
Sounds like I am not the first person to get the bug I will let you know about the 60.2 purchase and my ever growing obsession with B&O I suppose if I wasn't getting obssesed I wouldn't be on this forum.
bayerische
Ekenäs, Finland
Posts 4,770
Crashwhu:
Honestly I haven't searched Ebay for B&O for years.... But you just made me! Big Smile
Aaron Evans
London
Posts 39
Just brought the  60.2 s on eBay £59 I haven't seen them yet but the seller says they all work fine . Does that sound expensive?
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Dec 30 2012 10:54 PM
That sounds fine! With most B&O, the cosmetics are what really determine the price - electronics can be repaired - deep scratches of tears are much more of a problem.
Peter
bayerische
Ekenäs, Finland
Posts 4,770
bayerische replied on Sun, Dec 30 2012 11:10 PM
I think it sounds dirt cheap!
Aaron Evans
London
Posts 39
I noticed on the amp it has four ports? for speakers, would there be any benefit to use the RLS 60.2 s with the beovox 1000s or is it just over kill?
Aaron Evans
London
Posts 39
Aaron Evans
London
Posts 39
beaker
Posts 761
beaker replied on Mon, Dec 31 2012 2:16 PM
The rl60.2s are far superior to the 1000's and the 1"000s will limit how loud you can go.
I would get back on eBay and buy an amp of the right vintage as the 1000's and have two set ups!!
Aaron Evans
London
Posts 39
To be honest I am pretty impressed with the 1000s. As this is my first experience with B&O I have been impressed with all of my stuff so far, can't wait to hear the difference between them. Unfortunately I have not got enough room for another set up, otherwise that would be a great idea. But you never know as I said this is all getting a bit addictive.
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Wed, Jan 2 2013 6:03 PM
Crashwhu:
Yes.  When your FS says, "If you buy another piece I swear to God I will leave you."
elephant
AU
Posts 8,219
Rich:
Crashwhu:
so unfair Smile
and did you (foolishly) respond with, "and if you buy another:
  1. overlocker
  2. sewing machine
  3. knitting machine
  4. sewing/knitting/patchwork pattern
  5. tapestry pattern
  6. every so slightly and indistinguishable coloured ribbon/silk thread/wool
  7. patch of cloth
  8. bolt of cloth
  9. 45 litre container to hold some of the above
    so help me I will need to move into the garage/garden shed/outhouse/doghouse/our son's apartment ?"
BeoNut since '75
Rich
Posts 2,598
Rich replied on Wed, Jan 2 2013 10:15 PM
elephant:
Rich:
Crashwhu:
so unfair Smile
and did you (foolishly) respond with, "and if you buy another....."
No.  I said, "Yes, dear," which is actually more effective than any of the other replies.
elephant
AU
Posts 8,219
Rich:
elephant:
Rich:
Crashwhu:
so unfair Smile
very wise Smile
I on the other hand ,,,,,,, often speak and regret later !
BeoNut since '75
Aaron Evans
London
Posts 39
Just got the RL 60.2s put them in place of the 1000s the wife doesn't know yet she is still at work.I think she will notice the difference. I am not sure if I will make any promises as to whether or not this will be my last purchase as I still need a CD player. The sound from these is far superior to the 1000s I am very happy with them. Just not sure everyone will feel the same,fingers crossed.
Page 1 of 1 (27 items) | RSS
