Hi Gents
I have some problems attaching photos to a post.
Seems like only one can be attached at a time - correct?
Please guide me if I'm wrong, tia
Continued Merry Xmas and a Happy new Year to all.
/Leif
Just use a free hosting service like Flikr and you can post as many as you want.
Peter
I can recommend Photobucket.
Ready links to copy, ( [img] )
Too long to list....
You can also add more photos to one post using the forum software, it's just not very clear how to.
Hi, please explain if possible, tia.
Leif
There are several ways to add images and other files such as PDF's or ZIP files.
The first way is via the options tab when you are compiling or replying to a post where you can add one file.
If you want a series of images in the same post, then no problem, you use the "Insert Media" in the editor as outlined in the WiKi page HERE
You can upload images and other files to your own home page and reference them in any posting which means you can always find the files you previously posted quickly.
The negative with using third party sites to store images as you will find from time to that they get deleted or moved and therefore are no longer available to members to review, whereas any files added anywhere on Beoworld will always be available.
Regards Keith....
Thanks - just missed the Wiki option.......
