I was at my parents place last night and had a few minutes to play with the new tv (Beovision 11-46).
I've done a software update, the tv was installed the 15th of december and a update (17th of december) was available.
My dad had a "problem" with the remote, when pressing "radio" the Ouverture and the tv (in the same room but not linked) switch on.
I changed the video mode from 2 to 1 and it works perfectly.
So my main question is about the smart tv function.
I can't understand why, but my dad entered a pin code (or it's a bug ?) in the App center.
All the Applications installed (Youtube...) work fine but we can't access the App center to search for new Apps it asks for a pin code.
A message says if you forgot the pin code of Smart TV go online to get a new one but I can't find anything like that in the menus.
We wrote the security Pin code of the Tv but it's not that one.
If somebody has a clue, thank you !
Also, I tried to have a look of the service menu as usual but it doesn't work.
How do you access "service menu" on BV 11 (it's not the same as BV 10 or Avant) ?
I noticed a big difference with the tv from my BV 10 : the back stays "cool" while you can fry your eggs on the back of BV 10 !
What a tv the BV 11 is.
Cheers,
Gregory
The pincode is a self made one,
My Smart-tv screen says "Lock" on the yellow button, when i press it, it ask me to make a 4 digit pin code..
This is self made and has nothing to do with the master code :)
