Harmony Sound Center + LG E9?
flatwhite
Posts 49
flatwhite Posted: Sat, Mar 21 2020 10:21 PM
Title says it all... Wondering if it would be possible to use an E9 (instead of a C9) on an Harmony Sound Center?
Specifically interested in the physical fit along with the movement. Dimensions are very similar and I have verified that I can install the B&O App on the E9.
Anyone has tried this before?
Asking because current/future availability of C9 may be difficult.
1990
Posts 521
1990 replied on Sat, Mar 21 2020 10:25 PM
Are you asking whether an E9 will fit the stand? That I don’t know.
But if you can’t find C9 in your preferred size, you can take the CX. That one will fit perfectly.
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Mar 21 2020 10:58 PM
measuring from my harmony and taking the online measurements as facts it should be able to fit as there is 0.5cm in it and there is ~2cm room to the wings and you need 12mm to the wings.
I can't guarantee this, but that's what it looks like on mine.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
