Beogram 4000 Type 5215 - Self power-on issue
Velvet
Posts 19
Velvet Posted: Sun, Mar 22 2020 3:16 PM
Dear friends,
during this period of lockdown here in Italy due to Coronavirus I have time to try solving the "repeat" issue on my beloved Beogram 4000. A couple of years ago it was recapped, new reed glass elements fitted and everything checked and adjusted (thanks to the service manual and your great help here)
Everything went fine for some months, but at some point it started again to self power-on: it plays whole record, then the arm rise, goes back, off....And then on again and replay the record. Quite annoying.
If I press stop manually it powers off, but after some minutes it self-powers on again. I have to pull the plug to switch it off.
Is my 4000 the only one in the world with a repeat function? Big Smile
 Thanks for any tip..
Roberto (safe at home)
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
Craig replied on Mon, Mar 23 2020 2:30 PM
Sounds obvious but you could take a look at the contacts on the ON switch...….they are prone to causing problems as I well know.
Craig
Velvet
Posts 19
Velvet replied on Mon, Mar 23 2020 6:44 PM
Hi Craig,
thanks for your tip. I will check the contacts for sure!
Roberto
Page 1 of 1 (3 items) | RSS
