Since my Beolab 4s are failing, and I'm a bit reluctant to buy a replacement set because all of them are doomed to fail, I'm on the lookout for some new pc speakers.
They are to be used as main speakers while gaming, and since the computer is near the kitchen, music is occasionally played as well, sometimes at higher volumes.
Was looking into a set of Beolab 3s, but they are a bit over budget for what I'm willing to spend for a set of computer speakers. If I was to get a set of Lab3s, I'd hang them on the wall as rear speakers in the main room (with Lab 9s as fronts).
Anyone ever compare them to the Beoplay S8 set? Not really a pc speaker set, but I could image them installed around the computer.
Was looking at the more portable line-up as well (M3/S3 speakers), but manually powering up two separate speakers seems too much a hassle... Not sure if that's the route to go..
Any suggestions?
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
Thanks for sharing your experience. Is there any delay/lag when connected through wires? Is that through the 3.5mm jack, or via usb?
Is there autosense functionality, or do you have to switch them on and off manually (twice)?
crossbytje: Thanks for sharing your experience. Is there any delay/lag when connected through wires? Is that through the 3.5mm jack, or via usb?
No delay when wired. I've used 3.5mm for testing purposes. Have never tried usb; I should. My standard configuration is BT. Makes no difference when playing music, of course, and I just tested BT with a movie on the Mac to check the latency. To my surprise, latency is just about non-existent. I remember that BT latency was very much apparent when I was fiddling around with a MIDI keyboard.
Note: I've never been able to stereo-pair the two speakers when cabled, only wireless. When daisy-chained together, the second speaker duplicates the first.
HEY BEOWORLD: Does anyone know how to make a stereo pair of two Beoplay S3s, when using 3.5mm jack from computer to 1st speaker, and 3.5 daisy-chain to the second?
crossbytje: Is there autosense functionality, or do you have to switch them on and off manually (twice)?
IIRC, there's a stand-by mode, which implies autosense. That said, I leave them on all the time. It's a minimal power draw, iirc.
I still have a splitting cable from my BeoLab 4s, it takes a stereo 3.5mm connection and splits it into L and R channels. So I guess both can be set to act as daisy chained this way.
Not a fan of leaving them on all the time. Isn't there always a silent noise even if nothing is playing?
crossbytje:. Not a fan of leaving them on all the time. Isn't there always a silent noise even if nothing is playing?
No hiss, no hum.
As a follow-up, I dug up this information emailed to me by B&O Play support:
” You can switch between the two standby power modes by double pressing Image (the multibutton). In high power standby, BeoPlay S3 will have sense on all inputs and can wake up, and the product indicator will signal an action. This is also the default setting. In low power standby, the speaker will not have Bluetooth or input sense and there will be no product indicator signals.”
Hope this helps.
Beosound 9000 MK III, Beosound Century, Beogram 5005, Beolab 8000, Beolab 5000, Beolab 4000, Beolab 5, Beovision 8, Beovision 10, Beovision 5, Beoplay A2, Beoplay E8, Beoplay H6.
Interesting.
I'm not the biggest fan of their design though.
Is the M3 actually the successor of the S3? Or is it inferior?
I decided on getting a set of M3 speakers. Should be as good as the S3 I guess. + has airplay so I can use them on other occasions too for playing music in sync with my other speakers.
Will be interesting to hear how you’d connect these 2 M3’s to your PC.
I plan on using my splitter cable that turns a stereo 3.5 jack into a L and R channel, the same one I used with my BeoLab 4s. That should work right?
crossbytje: I plan on using my splitter cable that turns a stereo 3.5 jack into a L and R channel, the same one I used with my BeoLab 4s. That should work right?
You might be right.
But isn’t that a minijack to RCA/Cinch-R/L?
SteveSoundsHeavenly has this cable:
https://soundsheavenly.com/beolab-4-and-4pc/79-beolab-4-4pc-input-cable-minijack-connection.html
Is that the one/a similar one, that you have?
The S3 has a minijack input. MM
Yes, it was included in the box with the Lab 4 pc version.
The only difference with the one you linked is that mine has two mono plugs. Not sure if this will make a difference. The M3(/S3/all others) can probably take a stereo signal as input and mix it together. Not sure what will be mixed if one of those signals is nothing more than the ground. Maybe the speaker can distinguish between both?
Imo it could be a good idea to ask Steve (see the linked page - he is also a sponsor of this site) directly.
Mostly with the S3’s you run a minijack (stereo) cable to one speaker and then go from there to the other, also using a minijack cable - left -> right.
Also see this thread:
https://archivedforum2.beoworld.org/forums/t/21124.aspx
The pair of M3s arrived today and I must say, they sound really good! I'd say much better than my BeoLab4s.
I set them up using the app (not the Beoplay app which I already had for my H5, but a general B&O app with similar functionality (also lists my H5)) and tried Airplay for a few songs. They play in perfect sync, both mono.
They are now connected to my pc using the 3.5mm jack splitter cable that outputs L+R in separate connectors. Had a bit of trouble at first with them not powering up on a signal, but you can set the sensitivity of the signal detection for the LINE connection in the app as well. It's much better now. They power down after three minutes of inactivity, showing a dim white led. You can fix the volume level too for line signals, which is good so you can't accidentally change one of them with the buttons on the back. I am truly impressed with how well B&O thought this out!
They are at all times visible to airplay and bluetooth and prioritize this input over the line-in. They do need some time to revert to the line signal after stopping the airplay stream though. I'll still have to experiment with them a little further. (double pressing the button on the back cycles through the inputs, but that is a bit too much work for my taste..)
Anyway, I'm very happy with the upgrade, knowing I paid 'only' 325 for the set.
