Hello, looking for some help with my new Beolab 6000 speakers,
attempting to use airdrop through and Airport Express 2, through my amp, via my iPhone,
however, connection to speakers appears to be password protected?
anyway around this? Not sure who previous owner of speakers was so unlikely to be able to get this, was thinking a factory reset might solve it if that is possible?
can anyone advise if this can be done and how please?
thanks
Scott
The password is not on the speaker, more likely it must be on the Airport base.You must do a factory reset and configure the base again. Better search on any Apple related forum.
thanks for responding, will try what you suggest
Hey,
thanks for the advice!
worked a treat!
eteranally grateful
Happy to help.
