Beosystem 3 USB-Power?
TWG
Posts 1,672
TWG Posted: Sat, Mar 28 2020 5:49 PM
I've installed a superb Sennheiser BT-T100 Bluetooth transmitter and want to install one also to a Beosystem 3. The Beosystem 3 has an USB Socket BUT how can it be activated?
I only need it for powering the Sennheister Bluetooth transmitter but there's no power on the USB-Socket.
I've even plugged in a simple low current USB Led light for testing which doesn't light up either. Is there a special trick to activate the USB socket?
TWG
Posts 1,672
TWG replied on Sat, Apr 18 2020 11:42 AM
nobody knows?
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Apr 18 2020 11:53 AM
I haven't got a clue whether it is actually powered - the manual says that it's for service use.
However, you could try one of these: https://www.amazon.co.uk/PortaPow-PPSCA01-3rd-Data-Blocker/dp/B00QRRZ2QM
Sometimes blocking the data allows power to be extracted from USB sockets - I have had success in the past with car USB sockets. (eg powering a dashcam from a car-entertainment system's USB input, where the USB socket is looking for music data rather than supplying power by default.)
TWG
Posts 1,672
TWG replied on Sun, Apr 26 2020 1:06 PM
Thank you for the link. I ordered the USB adapter but it doesn't help.
I know that the USB port is for service use but I'm searching for a way to activate when I want its +5V service for my Bluetooth transmitter. Wink
leosgonewild
Helsinki, Finland
Posts 2,373
Would it be possible to use the trigger from a powerlink output?
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Apr 26 2020 3:37 PM
TWG:
That's a shame, but at least the adapter will be useful if plugging your phone into dubious charging points Smile
Page 1 of 1 (6 items) | RSS
