Eclipse Sound Center and LG Screens
This post has 4 Replies | 0 Followers
Tassos
Athens
Posts 323
Tassos Posted: Wed, Apr 1 2020 8:46 AM
Hello all,
With which LG Screens is the Eclipse Soundcenter fully compatible? (Home Control screen as well as I am using a BLI).
BeoMegaMan
Posts 601
The only screens which will give you full compatibility are the ones that come with the Eclipse. Only these screens have the SW to talk to the Home Control function of the BLI currently. Adding a non-Eclipse screen will make the newer /bigger LG screens simply turn on and off and add remote control functions.
Ah, you know... A little B&O here, a little there
flatwhite
Posts 49
We have a member here that has reported seamless integration with a C9 panel. But un theory all 2019 models up can install the B&O software via the LG app.store.
flatwhite
Posts 49
Tassos
Athens
Posts 323
Tassos replied on Thu, Apr 2 2020 6:47 AM
If you are talking about the user spezializten he reports that the home control screen does not come up and the favorite buttons do not work. Other than that he says that all sizes of the C9 panel have the possibility to download the B&O app and as a result "work" with the sound center.
https://archivedforum2.beoworld.org/forums/t/227.aspx?PageIndex=130
Page 1 of 1 (5 items) | RSS
