Bl3500
Squareheed
Posts 6
Squareheed Posted: Sat, Apr 4 2020 5:05 PM
Hi there,my friend has recently introduced me to b&o. I have a bv8 with a pair of bl6000 in my living room.(Sky q is connected to tv also)in the kitchen I have a bl3500 mk 1 which is connected with a master link cable from the tv. I have tried the options out the bv8 manual and the bl3500 manual and although I have a reading on bl3500 when I press sat on beo4 remote I have no sound.......can anyone help...cheers
Stoobietoo
Exeter, Devon, UK
Posts 692
If Sky Q is connected via HDMI you will get no sound via Masterlink. If it is connected via scart you should get sound.
Stoobie
Squareheed
Posts 6
Hi stoobie,thanks for replying to my post. Thought that sky q was maybe the problem.unfortunately sky q box has no scart .
Stoobietoo
Exeter, Devon, UK
Posts 692
You might be able to use something like this to extract analogue sound.
https://www.amazon.co.uk/Converter-Optical-Toslink-Extractor-HD-1080P-Black/dp/B016XMDKXC
Stoobie
Squareheed
Posts 6
Thanks,it’s worth a try and  not expensive.....I’ll get it ordered and give it a try.....thanks again.
Page 1 of 1 (5 items) | RSS
