Can anyone suggest how to remove a stuck battery cap on the BeoTime flute clock? I have a feeling one of the batteries fused to the cap.
Mike
Hi and welcome to beoworld. Maybe this video will help you:
https://www.youtube.com/watch?v=OZpwC1iiU2k
Go to 10 min 45 sec.
Another option will be to cut and adjust a paperclick so it can be fixed in the battery lid holes and then you can give some extra power to unscrew.
Hope this helps
Dimitris-
