Beogram 5000 turntable won’t turn on BeoMaster 5000 amplifier
Riclouis
Posts 5
Riclouis Posted: Mon, Apr 6 2020 8:09 AM
I just got a Beogram 5000 turntable.  When you play a record it is supposed to turn on the BeoMaster 5000 amplifier and go to the “Phono” input automatically. It’s not doing that. I have to turn on the amplifier and input manually.  Is there any way I can get this turntable to turn on amplifier?  Thanks.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Apr 6 2020 10:40 AM
Are the Datalink pins fitted in the Beograms DIN plug?
Is has to have seven pins.
Riclouis
Posts 5
Looks like all pins are there. Still doesn’t work. Doesn’t look like any corrosion either. Any other ideas?  Thanks. Ric
Dillen
Posts 13,191
Dillen replied on Mon, Apr 6 2020 5:54 PM
Could be a broken off lead inside the Beograms DIN plug or a bad safety diode inside the Beomaster.
Riclouis
Posts 5
I have another Beogram 5000 turntable just like this one. It does turn on the amp when you hit play on the turntable.  I replaced it with this one because the lamp in the dustcover stopped working. So I know that the amp recognizes signal.    This is odd.
Page 1 of 1 (5 items) | RSS
