Replacing old caps with bigger diameters than the new ones.
This post has 10 Replies | 0 Followers
Beobuddy
Utrecht, The Netherlands
Posts 3,972
For some time ago I had to replace all capacitors of a BM4000.
This Beomaster has 3 bigger caps. 2 of them are for the output stages and even a bigger one for the power supply.
The problem is that these bigger capacitors cost a lot more, because of their size (diameter).
Prices from about 25-30 euro each is quit common.
So, maybe this could be helpfull.
Another issue is that the caps inside the BM4000 are placed together in a bracket and are tightened that way. So, here's what I did.
First pic is the damage that a leaking cap can cause.
Beobuddy
Posts 3,972
Next picture shows the different dimensions between the old and new one.
Beobuddy
Posts 3,972
So, we start to take out the inner dielectric stuff.
Beobuddy
Posts 3,972
Below you can see that the new one fits inside the old, but drowns...
Beobuddy
Posts 3,972
So, I used a sheet of packaging material and started to cut..
Beobuddy
Posts 3,972
I only used the round cutted piece and filled internally the old cap with hot glue around the new cap.
Beobuddy
Posts 3,972
Finally the original capacitor filled with the new one in place.
It's difficult to see, but notice the bracket around the three caps. Just another several caps (orange ones etc) and trimmers to go.
BTW, this was a newer BM4000 version with 3 trimmers on each channel.
Evan
USA
Posts 3,621
Evan replied on Wed, Jan 2 2013 4:45 PM
GENIUS!
Never would have thought to do that in a million years.
Very good job sir!
Beo4 'til I die!
Orava
Finland
Posts 991
Orava replied on Wed, Jan 2 2013 4:57 PM
Very much cleaner than my (accidentally) way. Wrong polarity and "lots" of voltage, inners of cap popped out with nice sound effect... Messy....
tournedos
Finland
Posts 7,357
Orava:
Laughing Even small electrolytics can certainly make a bad mess.
Beobuddy's idea is actually used quite often with old valve sets - modern replacements can be outright tiny compared to the old high voltage capacitors with their paper dielectrics. The downside is that you can't see that easily when the replacement starts to leak, and it might also get a bit hotter with that extra enclosure around it. But, as we can see from the size difference in this case - realized over only 30+ years or so - there's been a lot of development in recent times as well, and the modern cap will probably stay in working order quite a bit longer than the original did anyway.
--mika
Beobuddy
Posts 3,972
I would add that the used cap is a 100Volt version.
The original one was 5000uF and 50Volt. The 100V was an afforddable one (8-9 euro) with the right diameter.
If I would have used a capacitor with the original specs, it could have been a (lot) smaller version.
The original idea was to use a replacement which could be used with the bracket.
Just to get an impression about sizes.
Down here, both has the same value, but different voltages (100V and 25V). I haven't a 50V at the moment in stock.
So compared with the original 50V version...
Page 1 of 1 (11 items) | RSS
