Beolab 50 Software issue
This post has 9 Replies | 1 Follower
stagegaard
Posts 6
stagegaard Posted: Fri, Apr 10 2020 8:19 AM
My Beolab 50 speakers tells me that the software update is sufficient, but both speakers have the 2.2.0.6544 version. Does anybody know have to solve this problem?Wink
Mikipidia
Posts 2,169
Mikipidia replied on Fri, Apr 10 2020 1:05 PM
Sometimes it takes a few tries, sometimes it helps to write to your dealer and ask him to contact HQ to push it through to your serial nr. Or you can update them via a clean usb stick with the software on it.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
stagegaard
Posts 6
Thanks for good suggestionsSmile
stagegaard
Posts 6
Where do you exactly find the software update btw? I can not find it on the B&O website!?
stagegaard
Posts 6
I still have the same software issue, HQ can not help. Do you know where I find the the software update?
Thank you! Niels
stagegaard
Posts 6
Thank you! Niels
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Aug 15 2020 3:17 PM
What do you mean HQ can not help? What about your dealer?
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Aug 15 2020 3:56 PM
Iam on 2.3.4.7045 and it came via auto updating, so I don’t know where to get it other than that. Wire your speakers for internet and try several times. That seems to be the way to do it. Your dealer should be able to provide you the software too
Razlaw
Posts 4,345
Razlaw replied on Sat, Aug 15 2020 9:36 PM
Mikipidia:
Iam on 2.3.4.7045
Same version on mine
stagegaard
Posts 6
Thanks a lot! Wiring the speakers to the internet differently helped the speakers to find out that the were surpose to update, they try but without succes, yet. HQ refers to the dealer, and my dealer is a idiot...completly out of reach, mentally.
Page 1 of 1 (10 items) | RSS
