Hi
I need four new belts to my Beocord 6500 t493. Where would you recommend that I buy them?
Best Regards
Brian
I have the correct belts, also for the drawer motor.I also have new rubber tires for the drawer wheels.PM or email me.
Please avoid at any cost eBay belts. They are sometines not even rectified, or real belts but O-rings!
Martin's belts are probably going to work for a very long time. Those I bought from him 10 years ago are still going strong.
The ones from eBay, well, went to the bin.
Only recently I replaced a Beocenter 9500 CD door belt (no stock from Martin, unfortunately), it lasted 3 months. The eBay seller tells me he supplies the local B&O repair shop in UK.
Yeah right.
Jacques
