Hi all.
I repaired the cable of the speaker of my Beotime.
Before to mount again the Beotime I would change the contact folio of joystick.
I can not find any spare parts service. Could you help me?
Thanks in advance.
Tony
Hi all,
I bought the part in a B&O store.
Thanks and Best Regards
Hi, I have the same problem.
Is it essential to change part 9003 because you need to break it when opening the Beotime, or is it just recommended?
Is the part available at all dealers through the B&O network?
Many thanks
Hi Tony,
can you tell me in which store you bought that contact folio? I've been looking for this part like crazy but haven't found it anywhere yet...
Thanks in advance,
Daniel
could you specify WHICH B&O store offered the contact folio?I search quite hard for this spare part and am very grateful for any tips!Best regards,
