Beolab 18 & 19 move to Beolab 5?
This post has 49 Replies | 0 Followers
mr_anders_son
sweden
Posts 1,710
mr_anders_son Posted: Sun, Apr 12 2020 2:18 PM
I wonder if I shall move from Beolab 18 & 19 to Beolab 5.
Any thoughts about that? (Not design wise)
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Chris Townsend
Qatar
Posts 3,531
I'd stick to what you've got. I had some 5s, and I felt unless you could truly play them at a volume that befits them, you'd be better with your current setup.
I found the 9s at the volumes I played them to be better to be honest, but then again the 5s never really got the chance to get going.
oli
Southeast of France
Posts 141
oli replied on Sun, Apr 12 2020 4:28 PM
Sound wise, of course, nothing comparable with your current setup
mrCTE
Posts 70
mrCTE replied on Sun, Apr 12 2020 4:47 PM
Super interesting question: I have been considering the same in the sense that I am pondering BeoLab 18+19 or a pair of Beolab 5s.
I’ve never heard the 5s, only the rumours! But I did listen to the 18+19 set up and thought it was pretty fine. It would be good to know what other esteemed B&O customers think!
Millemissen
Flensborg, Denmark
Posts 14,680
The best and only way to know, is to listen to both sets in your own room.
On the other hand, both are excellent.....you probably could be happy with each of them.
Just don’t think too much about the set, that you did not go for.
Mikipidia
Posts 2,169
Mikipidia replied on Sun, Apr 12 2020 6:29 PM
How big is the room and is it a house or appartement? I personally would need more info to make a judgement Stick out tongue
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Sun, Apr 12 2020 6:52 PM
I have BL18/18/3 in my living room and to my experience the setup is key. I’m i n the process of tweaking the settings through my Eclipse. To get the most out of the speakers it is a delicate process of both placing the BL19 and adjusting the settings of the bass management. I want the bass to come from the BL18’s to the point that the ABL kicks in and the BL19 takes over AND the BL19 to give the very low bass even on low sound levels.
I find this a difficult process but in the progress I also learn to appreciate the performance of my speakers!
I can only guess that the BL5’s have the performance I’m looking for out of the box. They can calibrate the sound to the room specifications and play their best sound immediately.
In short, the BL5 should outperform the BL18/19 combo but if set up properly they should be close enough (I think haha).
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sun, Apr 12 2020 8:20 PM
The BL19 has two 8 inch woofers and the BL5s have two 15 inch woofers. If true deep bass is your goal there's no comparison. The 5s have enough bass they can untie your shoes and then tie them again.
Jeff
Fansastic
Posts 768
Fansastic replied on Sun, Apr 12 2020 8:23 PM
Jeff:
Jeff
Haha that is some nice feedback I like!
seethroughyou
UK
Posts 999
The only area the BL5 disappointed in was low volume listening. I felt they didn’t perform until middle to high volumes. I’d be interested to know how they’d perform with something like DIRAC room correction in a the middle to high frequencies.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sun, Apr 12 2020 11:56 PM
seethroughyou:
Sounds like they need room correction less than a source with a loudness contour function.
Jeff
Chris Townsend
Qatar
Posts 3,531
seethroughyou:
This was my experience too.
oli
Southeast of France
Posts 141
oli replied on Mon, Apr 13 2020 10:34 AM
I have to agree at 100% with that, and not only for the BL5 but in general. Before thinking upgrading the hardware to improve sound, consider passive and/or active room correction. It is key. As I said before, nothing comparable between BL5 and BL18+19 in a correct acoustic environnement, the BL5 will outperform the other combo, far far far away.
The BL5 calibration is only for ABL, calibrating on the average response of the room, giving sometimes worst results than not calibrating at all, depending of the room and the placement of the speakers and the listening position. It is not a DSP like in BL50 or BL90. But you can easily add this fonction adding a Dirac or something else that will adapt the couple speakers/room. Personnaly, I added a Lyngdorf TDAI2170 (danish company), in a 100% digital chain, with some acoustic panels (up to the WAF limit ^^) in the back. It is night and day, with a lot of dynamic added, even at low volume. And it is also giving the possibility to get a focus or wide sound to the BL5 (wide by default with the acoustic lenses), it is changing a lot of things when you are listening at a fixed position. It also includes a digital equalizer if ever you want to adapt the sound (I keep it in Neutral mode)
Acoustic panels:
As you can observe, the room is REALLY BAD regarding acoustic with these 2x 8 meters of windows on each side, quite large with almost 90m2, with a lot of empty, plate and reflective surfaces from the floor to the ceiling
Inside the B&O cabinet, the Lyngdorf (only used for the Room Perfect feature, feeded with USB from the Mac Mini, SPDIF output connected to the DAC of the BL5) on the top, the Mac Mini+Audirvana as source (embedded Tidal for streaming) and all the boxes for Beolink and TV reception, everything controlled with the Beo4 with a Lintronic IR box.
talfaia
Posts 22
Silver Member
talfaia replied on Mon, Apr 13 2020 10:15 PM
Hi Oli, this is great. For music, where do you have the volume control? In the TDAI2170 or in the BL5?
talfaia
Posts 22
Silver Member
[duplicate]
oli
Southeast of France
Posts 141
oli replied on Tue, Apr 14 2020 7:24 AM
talfaia:
Not in the TDAI. The Lyngdorf permits passive speakers connections only to use with the Preamp/Amp part of it.
The BL5 are connected in SPDIF to the TDAI-2170, and also in Powerlink to the BV7-55. So, more specifically, the volume control is adjusted by the BV7 as it is one of the rare BV models being able to send the data control through the Powerlink MKII cable to the BL5 (I think, to be confirmed, it is limited to the Beovisions using the Beosystem 3 in them, so BV7, BV9 and BV12 MKI).
The BV7 is also opening the SPDIF port of the BL5 through the CD command to get the digital signal from the Lyngdorf. It is why you see a Beomaster 4500 linked to the BV7. I use it sometimes for the FM, but it is mainly used as a CD command receiver on the Beolink, even if there is nothing connected to the CD input of the Beomaster.
There is multiple advantages to not use the integrated volume control of the BL5 when you are in an hybrid setup like me (with B&O and non B&O stuff):
1/ you have a full Beo experience regarding Video and Audio integration (no need to switch the L.OPT on the Beo4 each time your change the source), piloting everything with the Beo4 with BV PUC or with the addition of a well known Lintronic box.
2/ the source and the volume setting is visible on the BV7 whatever you are sending to the BL5 (the TV screen remains off)
But we are off topic, to be back on it, Mr_ander_son, if you are happy with your BL18/19, you might keep them and improve the acoustic experience with an active or passive room compensation, It is my advice. If you want to step up, go for the BL5, but it would be a pity to not consider the acoustic treatment of the room also while doing it, to fully enjoy this piece of audio art that is the Beolab 5.
I suggest everyone to read the excellent blog of Geoff Martin about room compensation topic: http://www.tonmeister.ca/wordpress/2015/06/30/bo-tech-active-room-compensation/
The kind of source and way to transport/convert it is also important to consider, and can give a lot of improvement in your setup. What are you using currently as music source, and what are the BL18/19 connected to ?  A few months ago, there was an interesting thread on the french part of the forum, explaining how the person was rediscovering his speakers, and was noticing how his old Beolab 8000 are good sounding, just improving some parts of the chain.
mr_anders_son
sweden
Posts 1,710
Thank you all!
I have now sold my 18&19.
So now I have to find some good BL5Smile
Emil Jensen
Denmark
Posts 766
It is possible to find some good units,
I was lucky to find some that had been used as surround speakers.
A lot is on sale because people are upgrading to Beolab 50.
I had to pay 45.000kr. Danish kr. which I find a steal.
So good luck to you, and you will be please with the decision :)
Fansastic
Posts 768
Fansastic replied on Tue, Apr 21 2020 7:52 AM
Please share your experience with us how you find the difference between 18/19 and 5’s
Chris Townsend
Qatar
Posts 3,531
mr_anders_son:
Thank you all!
So now I have to find some good BL5 BeoVision Eclipse 55"...BeoLab 18 as FRONT....BeoLab 4000 as REAR....BL19 SUB....BV5 HD....Beoplay V1-40....BC6-26....Beosound 9000....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H8....H6 90´s Rose Gold edt....Form 1....U70...
When you find a pair, get the serial numbers checked out to make sure they are what’s being described.
Long storyErm..
mr_anders_son
sweden
Posts 1,710
Chris Townsend:
Long story Beovision Eclipse, BeoLab 17,Beolit 15, Beoplay A2 Active
Yes!
Where can I check that?
Dealer?
mrCTE
Posts 70
mrCTE replied on Thu, Apr 23 2020 8:55 PM
A dealer you know and trust!
Chris Townsend
Qatar
Posts 3,531
mrCTE:
That’s where my problem started unfortunately.....
mr_anders_son
sweden
Posts 1,710
Before
Big SmileI got them
1990
Posts 521
1990 replied on Sun, Apr 26 2020 1:12 PM
Stunning! The BL5’s are an even better fit (especially with regard to the lamp switch and the painting). What an upgrade :)
Mikipidia
Posts 2,169
Mikipidia replied on Sun, Apr 26 2020 1:50 PM
Looks amazing!!Big Smile i like everything i see honestlyWink
oli
Southeast of France
Posts 141
oli replied on Sun, Apr 26 2020 4:05 PM
congratulations for this great upgrade ! :-)
Duels
England
Posts 2,553
Duels replied on Sun, Apr 26 2020 4:42 PM
Absolutely beautiful.
Michael
Sweden
Posts 2,578
Michael replied on Sun, Apr 26 2020 4:43 PM
Interesting move! I have considered going from
20 to 50 but maybe 5 is an option as well.
Duels
England
Posts 2,553
Duels replied on Sun, Apr 26 2020 5:02 PM
Can we have a pic of the other speaker too?
Chris Townsend
Qatar
Posts 3,531
mr_anders_son:
Before
I got them
BeoVision Eclipse 55"...BeoLab 5 FRONT....BeoLab 4000 as REAR....BV5 HD....Beoplay V1-40....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beosound Stage....Beoplay S3....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H9i Rimowa....6 x H6....Form 1....U70...
Very nice sir
mr_anders_son
sweden
Posts 1,710
The other one!
Jaffrey2230
Washington DC
Posts 520
IMHO the BL 5 aesthetics works better in your space. It just looks much much cooler. Great move!
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
Duels
England
Posts 2,553
Duels replied on Thu, Apr 30 2020 1:58 PM
mr_anders_son:
The other one!
Thanks for posting the additional pic. Looks absolutely gorgeous.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Thu, Apr 30 2020 2:58 PM
Jaffrey2230:
I agree. In fact, in my opinion, the BL5 is the most attractive speaker B&O, or anyone, has ever made. Followed closely by the BL8000. In the TV series "The Expanse" which takes place 200 years in the future, in one scene in a person's house you can see on BL5. And I suspect the majority of people who saw the show had no idea that it was a speaker.
Jeff
Steph
France
Posts 1,059
Steph replied on Thu, Apr 30 2020 3:20 PM
Congratulations Mr Anders son :-)))
The Beovision Eclipse with the piano black stand is truly amazing in front of your dark wall! Wink
pauliander
Posts 81
To Jeff: Totally agree with that. Even my wife likes them a lot. Before the BL5 I had JBL K2 series 4800 with 2 15 inch woofers in front. Magnificent sounding speakers especially for jazz. But pizzas she called them. They are gone and no regrets with BL5 since then. Replacing them will be difficult. BL50 and BL 90 are not really my taste. As long as they keep playing I am happy Stick out tongue
Fansastic
Posts 768
Fansastic replied on Thu, Apr 30 2020 6:01 PM
Congratulations with your new setup. What a nice interior design also, true B&O spirit and is it only me or is the BL5 getting even better in age. The form and proportions are really nice and design wise so much better then the BL50’s. The 90’s are best behind curtains imo.
How do you rate it sound wise compared to your former set up? Especially at lower levels also huge difference?
mr_anders_son
sweden
Posts 1,710
When it comes to design, Beolab 18 & 19 is top class. But I've never been happy with the sound. Probably bl 19 has been misplaced.
In any case, I like the sound picture much better with bl5.
It's a big difference.
Which should be with bl5 considering the price.
When it comes to decor, I think it works too, though they are more eye-catchingGeeked
mr_anders_son
sweden
Posts 1,710
And at lower level BL5 plays in another league.
Page 1 of 2 (50 items) 1 2 Next > | RSS
DigiCert Secured Site Seal
