hello
Now the problem is that the Beo Center 9000 product does not play the CD, the door opens and the servo board C2103 needs to be replaced.
Please tell us the site address where you can purchase.
I can supply the correct capacitor kit for the servo board in your Beocenter 9000 - including the correct component for C2103.Email or PM me.
CDM 2/29
I just attached a photo by email. Please check once.
You keep posting the same question.You cannot buy a new disc drive for Beocenter 9000 anywhere - but capacitor kits are available for most servo board versions, and that is where mostproblems are. (DON'T touch the laser current adjustments! or the repair job will be much bigger).
To see if a kit is available for your servoi board version, I asked for a photo of the servo board.You sent me only photos of the CdM label and the disc clamp.Martin
Thank you for answer.
I'm not sure which part to shoot because I don't know the product.
If you can see where the part of the picture I sent is, can you mark it?
I sent a few photos attached today. Isn't that the picture?
I received no photos from you today yet.The servo board is the board that has capacitor C2103. It sits at the underside of the CD drive.
Should I open the cd drive and check it?
Take out the complete CD drive.Take a photo of the numbers found in the corner of the board that sits under the drive and email to me.
Mail sent again. please check
Okay, I'll open the drive and send you the pictures again
It could not be completely disassembled, but it is number 03217 on the red sticker. Is this correct?
I'm not an expert, so I can't open it anymore.
I now received four photos from you - of innards and everything else but the servo board.I have replied with a photo of a similar board and a photo of the numbers in the corner.The CD drive is held by two screws, a plastic bracket and it sits in four springs. Dismount the four screws and take out the drive. You will have to do thisto replace the capacitors anyways.
I sent it as an email attachment. please check.
Yes, that's it.You have email.
I sent an email. please check.
I'm sorry, please check your e-mail one more time
I sent an e-mail, but there is no reply yet, so please check it.
