Best guess on what my 1700’s problem is
This post has 5 Replies | 0 Followers
Oldmactech
Posts 13
Oldmactech Posted: Mon, Apr 13 2020 7:19 PM
New to B&O, recent acquired 1700 with Mc20e. Connects via RCA jacks. Nothing but loud hum from both channels. Cartridge/stylus appear intact. basic continuity is good.
Bad cartridge? Anyway to test the cartridge with a meter?
This should connect to phono input? or somewhere else?
thanks.
Oldmactech
Posts 13
Additionally, the axial capacitor (470uf I think it is) on the control board, has oozed some electrolytic, could that have sone effect or does the board only control the various movements?
Oldmactech
Posts 13
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Apr 13 2020 8:12 PM
There are no electronics in the signal path.
All electronics are for the operation.
The cartridge could be bad, but I think the hum problem is more likely to be rooted in the conversion to RCA that has been attempted.
There should be a separate chassis ground lead accompanying the two RCA plugs, - it is to be connected to the metal chassis of your amplifier - typically a small fingerscrew near the turntable input sockets.
The leaking capacitor should of course be replaced. I would recommend you grab a servicekit. It has new components for all
electrolytic capacitors (axial, radial and tantal) - new speed adjustment trimmers, a new fuse and a new belt.
PM or email me.
Oldmactech
Posts 13
Oldmactech replied on Tue, Apr 14 2020 12:45 AM
Understood, thanks.  The RCA cabling seems professionally done, good quality cable. I have bypassed the cable with test patch cable, still nothing but hum.  Seems to me if it were bad cabling, I would still be able to get some cartridge output.  If I touch the tone arm the signal is active I do get loud scratching through the speakers as if the RCA connecting is at worst partially functional.
thanks.
Oldmactech
Posts 13
Oldmactech replied on Tue, Apr 14 2020 12:48 AM
Forgot to say, there is a functioning ground cable, I will double check too that it is mounted correctly.
Page 1 of 1 (6 items) | RSS
